plenum torque
Old May 5, 2009 | 12:51 AM
engineblock's Avatar
engineblock
Default plenum torque
I did my plenum pan and when i started it i ran it for 2 minutes and when i stopped it my spark plugs were full of oil,
My question is what torque did you all torque the plenum pan ( i did read the haynes book but found only in torque in ilbs but i want to know the ft lbs
Old May 5, 2009 | 07:14 AM
dhvaughan's Avatar
dhvaughan
going from memory here and this may not be right, but its something like 84 in pounds.
to convert to ft/lbs, you divide by 12, so it would be 7 ft pounds
sorry about the oil, could it be something else, like PCV or valve seals or something. i'm just hoping for you. peek down in TB..
Old May 5, 2009 | 07:46 AM
Laramie1997's Avatar
Laramie1997
1 inch pound force = 0.0833333333 foot pounds
Old May 5, 2009 | 11:51 AM
nolazach's Avatar
nolazach
I feel your pain. Reminds me of the time I replaced my water pump and timing belt and after I put it all back together my Front Main Seal starting pouring out oil and I had to tear it all down again and replace the seal.
Stuff like that happens when you DIY, but it still saves you $$$ and gives you a fun hobby.
Old May 5, 2009 | 12:48 PM
sungod's Avatar
sungod
Here is the TSB http://dodgeram.info/tsb/2000/09-05-00.htm Along with a conversion chart: http://www.onlineconversion.com/energy.htm
Old May 5, 2009 | 11:39 PM
88dakv6's Avatar
88dakv6
i just impact it on, never had a problem.
Old May 6, 2009 | 10:35 AM
highlander73's Avatar
highlander73
Not those 84 in-lb bolts you don't. Plenum (and intake manifold) bolts have a specific torquing sequence that requires increments of something like 12 in-lbs at a time. No job for an impact gun.
Old May 6, 2009 | 10:14 PM
dhvaughan's Avatar
dhvaughan
i think he's joking. surely he's joking. hmm, i hope he's joking...
Old May 7, 2009 | 01:46 PM
99DRAM31887's Avatar
99DRAM31887
i don't think he's joking guys :/ oh boy lol
Old May 7, 2009 | 02:09 PM
Laramie1997
That is priceless. You are going to use an impact gun on an aluminum piece of metal? Good luck with that, I am sure you are going to have fun replacing warped pieces.
I nominate him for resident dumbass of the week award...
