CEL on again!!
Old May 5, 2009 | 09:23 PM
ice01's Avatar
ice01
Cool CEL on again!!
Hey I got a CEL today and got it checked at Advance Auto. The reader showed it was an o2 sensor. Bank 1 Sensor 2 high volts. Is this the one before or after the cat? Does this merely mean the cat is bad or do I have other problems like clogged cat, etc.....
Old May 5, 2009 | 09:30 PM
J415's Avatar
J415
Should be your pre cat sensor. If your cat was clogged, you would know, because it would cause your engine to misfire in most cases. Also, it would rattle like a bunch of bolts are loose. Specifically, what code did it throw?
Old May 5, 2009 | 10:25 PM
sit22 II's Avatar
sit22 II
that will be the sensor after cat
if the code said high vltage i would do the sensor first
Old May 5, 2009 | 10:32 PM
Laramie1997's Avatar
Laramie1997
1+ the bank 1 sensor 2, would be post cat. Nothing major to worry about, just an annoying light that will show up on your dash.
