plenum pan
Old May 6, 2009 | 11:40 AM
engineblock's Avatar
engineblock
Default plenum pan
This is my second time i do the plenum pan in 2 days, i just cant get it right, well i was thinking that 7 foot ibs of torque for the belly pan is too little, i followed the procedure step by step and still nothing, oil is getting into thechamber alot worse then when i torqued the belly pan by hand
Where can i get an aluninumpan so i can weld the pan to the intake
Old May 6, 2009 | 11:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Are you using the original pan and bolts? Or do you have a Hughes or APS replacement?
Old May 6, 2009 | 11:47 AM
engineblock
the original
Old May 6, 2009 | 11:54 AM
zman17's Avatar
zman17
Then that's the problem. The bolts are most likely too long.
Old May 6, 2009 | 12:03 PM
engineblock
Well im going to be doing it again one last time using more sealant see how it goes
So the maximum torque for the plate is 7 foot pounds right
Old May 6, 2009 | 12:08 PM
zman17's Avatar
zman17
Yes, but more sealant is not going to help if the bolts are too long . Simple as that.
Old May 6, 2009 | 12:17 PM
olyelr's Avatar
olyelr
Like zman stated, the stock bolts are too long to actually torque the pan/gasket down, they just bottom out. If you insist on using the stock stuff, I would suggest griding the end of the bolts down a little bit so they dont bottom out before the pan is torqued.
But, you might as well consider replacing it with a Hughes or APS kit... much better than the stock crap. It is basically a solid, thick (like maybe 3/8 of an inch) piece of aluminum that pretty much ends the dreaded leaky plenum.
Old May 6, 2009 | 01:31 PM
J415's Avatar
J415
make sure you clean the mating surfaces very well and don't touch it afterward. could be as simple as that...but I think it's the bolts as well.
Old May 6, 2009 | 03:13 PM
95RamIT's Avatar
95RamIT
also, maybe if its your daily driver and cant deal with down time you could try going to ace and getting shorter bolts?
