Heads/Cam/Shocks Question
Old May 7, 2009 | 07:17 PM
BlueDemon01's Avatar
BlueDemon01
Default Heads/Cam/Shocks Question
For my 318, could I just buy a pair of 360 heads and slap em on? Or would I need to upgrade some other parts of my motor?
Has anyone cammed out their 318? And possibly without pulling the motor? I've heard you can do it just by removing all the fan/shroud/etc and replacing it easy.
Also, if I do coil spacers/add-a-leafs to lift my truck, will I need longer shocks or stick with stock length? I'm gonna replace them anyway
Old May 7, 2009 | 08:43 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Well The headers will or should fit. For the lift it depends on how high you want to go odds are yes.
Old May 7, 2009 | 09:29 PM
xskylinedx's Avatar
xskylinedx
Heads are the same for the 318 and 360
Haven't done a cam swap myself but I'm really sure you can do it without pulling the motor
Shock length will depend on how much lift. Contact whoever your going threw for the lift.
I would recommend contacting http://www.topguncustomz.com/index.php
Old May 7, 2009 | 09:35 PM
BlueDemon01
Would the 360 heads even do anything for me?
Old May 7, 2009 | 09:38 PM
BlueBeast2's Avatar
BlueBeast2
yes same heads. However stock heads suck and do crack sometimes.
Yes you can do a cam swap without pulling the engine
Most likely you will need longer shocks
Old May 7, 2009 | 09:39 PM
BlueBeast2's Avatar
BlueBeast2
you posted as I was posting. I'm pretty sure they are the exact same head. That said won't do a damn thing for ya
Old May 7, 2009 | 09:44 PM
dodge15004x45.9
In the upper RPM's yes they will.
Old May 7, 2009 | 11:19 PM
BlueDemon01
Has anyone tried out different compression heads? Since we have 9.1 I talked to a guy who said he had 11.1 edelbrocks on his.
Old May 7, 2009 | 11:27 PM
RM_Indy's Avatar
RM_Indy
Bumping compression will help, but you will need a real tune though cause it will cause ping with a can tune.
AC condensor stays in, rad/fansshroud need to be pulled to get the cam out
Old May 8, 2009 | 12:17 AM
BlueDemon01
Nice. now can someone direct me to where I can educate myself on cam/lifters?
I am clueless when it comes to ratios and lifts right now.
