VSS wire location
Old May 9, 2009 | 06:32 PM
spudbud2005's Avatar
spudbud2005
Default VSS wire location
My cruise control hasn't worked ever since i got my truck my light will come on when i start the truck and will go off..so when i mash the on off button on my steering wheel...no light...so i looked at everything...and noticed that my Vehicle Speed Sensor....had no wire running to it...so does anyone know how the wire runs and where it connects to? i took 2 pictures of it but its 4x4 and is located on my transfer case....btw my truck is a 98 1500 ram...but thanks for helpin me out!
Old May 9, 2009 | 07:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The sensor on the tail shaft on a 98 does nothing. The vss is on top of the rear end. If the CC is not working , replace the brake pedal stop light switch and check for vacuum leaks. The main leak to check for is under the battery tray, there is a vacuum hose under there that is the most likely to go bad.
Old May 10, 2009 | 01:13 AM
spudbud2005
ok thanks for your help and about a year ago i replaced my brake switch...but i do have a vacuum leak somewhere but i just havent found it yet because my vents shut off and it sounds like my defroster comes on when my engine is on a load like when i go up hills and mess....but ill check out for the leaks...and i was thinking that my CC would be an electrical problem because when i mash my on off switch...the light wont even come on...but thanks for the advise!
Old May 10, 2009 | 06:42 AM
zman17's Avatar
zman17
It is most likely a vacuum leak, because you have the wild vent problem. If you do a search on here, there are tons of threads about it. There is also a DIY on cleaning the CC switch.
Old May 10, 2009 | 09:49 AM
spudbud2005
ok thanks ill give it a check tomorrow and ill let ya know what happen
