Leveling kits all that difficult?
Old May 10, 2009 | 01:53 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by dhvaughan
if there's any doubt about spring pressure, you can't rent/borrow a coil spring compressor from autozone or advance.
You Can't? What a bunch of jerks they are.
Old May 10, 2009 | 03:14 PM
Relex's Avatar
Relex
I put a leveling kit on my 01 about a month ago. I got a Hell Bent Steel 2" kit and it was an easy install. Even after dropping the sway bar I still had to rent spring compressors from Advanced (got every penny back when I returned it so that was great). Here's some before and after pics of my truck and I'm very happy with the result.
Before
0408091620-00.jpg?t=1241982848
After
0409091906-00.jpg?t=1241982867
Old May 10, 2009 | 04:28 PM
wjxavier's Avatar
wjxavier
that looks really good...i guess i'll chock that one up on the list lol
Old May 10, 2009 | 05:23 PM
dhvaughan's Avatar
dhvaughan
oops
Old May 10, 2009 | 05:35 PM
pcfixerpro's Avatar
pcfixerpro
If you unbolt the stabilizer bar links, you shouldn't need to compress the springs.
I unbolted the sway bar and it did drop lower, but the spring wouldn't go into the pearch without some persuasion. I had to compress about 1/4" or so, so it wasn't that bad.
Old May 10, 2009 | 06:57 PM
BigRedRam95's Avatar
BigRedRam95
how come you had to drop the sway bar when I put my Hell Bent Steel kit on I did not drop the sway arm or use a spring compresser
Old May 10, 2009 | 07:50 PM
pcfixerpro's Avatar
pcfixerpro
I think part of my problem was the truck started out being jacked up real high... but the jack stands kind of sunk in my driveway a bit. I bet i wouldn't have had a problem at all had that not of happened
Old May 11, 2009 | 09:07 PM
vmann's Avatar
vmann
another thing is... did all of yalls trucks come with blocks in the back from the factory? Mine did and it seems fairly level to me
Old May 11, 2009 | 09:12 PM
BigRedRam95
mine has blocks to and my truck looks level to me
Old May 11, 2009 | 09:15 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Why not just got 3"?
