Throttle linkage play
Old May 10, 2009 | 01:11 PM
aim4squirrels's Avatar
aim4squirrels
Question Throttle linkage play
So I've been having a little tiny problem with bogging occasionally and I think that I've found the answer. I think there's a little too much play in the throttle cable. I'm not sure if there is supposed to be any play at all, so I snapped a pic of how much I have and I'd appreciate any opinions:
That's how much I can pull out until the cable tightens up and locks. It that too much? I know I can fix it with some vac line or fuel line zip tied to the end, but I don't know if I should leave any play at all.
Thanks for the help.
Old May 10, 2009 | 01:36 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It's just both ends, and the pulley thing behind your finger getting worn . You can do the rubber hose/tie wrap fix, but I would leave a little play, about half of what you have. I don't think that's going to be your bogging problem though.
Old May 10, 2009 | 05:02 PM
dodgeram07's Avatar
dodgeram07
to many WOT runs?.hehehehe
no mine is like that too, you can bend the top of the gas pedle back a little and cut a old pen( like a small piece of pvc pipe) what works to
