X pipe OR H-pipe?
Old May 13, 2009 | 12:03 AM
lb79theone's Avatar
lb79theone
From: Maine! ( GET A HOLD OF ME IF YOU WANT TO GET ME ON FACEBOOK.COM, AND CARDOMAIN.COM)
Question X pipe OR H-pipe?
I want to keep the same setup for my exhaust, but want to put in longer tips, a Super 44, and a x pipe or a h pipe.
What "pipe" should I use?
Tell me everything you know about each "pipe" so it will help me with my decision.
Brendon.
Old May 13, 2009 | 12:17 AM
dakotas ram's Avatar
dakotas ram
h is supposed to be louder and raspier
x is more mellow and a little better scavenging
most guys say the better sound from the h is worth the minimal diff in scavenging
Old May 13, 2009 | 12:21 AM
nemesis_SS's Avatar
nemesis_SS
our engines fire like so: LRLLRLRR and its those double pulses which highlight the difference between h and x.
In an H configuration, your basically working with two straight pipes since the gasses rarely make a 90 degree turn - especially at high pressure (why the power gain is lost at high RPMs). So when the gas is travelling very quickly, your still running down one pipe (though there is a slight vacuum effect as one pulse draws up the next pulse on the other side)
In an x config, those double pulses get a better chance to split up at the x junction. So then its like doubling the net diameter of your system.
In either case, your better off than a single exaust.
h pipe:
- cheaper
- less power gain, because the gasses "tumble" which is why you get the next point
- sounds better (more grrrrburble burble burble burble burble pop burble burble)
x pipe:
- more power (at higher RPM range)
- more money
- less ballsey noise becasue gasses travel faster, which is where more power comes from
Old May 13, 2009 | 01:57 AM
Mowhawk's Avatar
Mowhawk
^ beat me 2 it. Basically you can think of it as a rule of thumb:
X pipe- Performace main issue
H pipe- Sound main issue, still some performance.
IMHO, you should go with the X pipe, your still going to have a great sound with those longer tips and the 44. Unless you plann on running true duels you might as well use an X.
Old May 13, 2009 | 02:01 AM
dakotas ram
how much can realistically be expected from both?
Old May 13, 2009 | 02:10 AM
Mowhawk's Avatar
Mowhawk
for our rams....maybe 1 or 2 hp difference
Old May 13, 2009 | 02:13 AM
dane25's Avatar
dane25
i'd choose H pipe...
Old May 13, 2009 | 03:17 AM
dakotas ram
so, its really just what sound you want?
do you think i would be better sticking with my full single 3" turbo or going to duals with an h?
Old May 13, 2009 | 03:39 AM
Mowhawk's Avatar
Mowhawk
Well not is not really what sound you want. It does play a roll in performance, what im saying is that with a stock engine and swapping out exhausts it really wouldnt make a difference. An example, Nascar runs X pipes over H pipes cuz it pulls more hp, so in my mind if the 800hp cars think itts good enough so do I. For us though.....not much of a difference.
As for swapping your setup...idk, not sure what would be louder or not. If u like ur sound how it is dont change it, only thing I could really think of tha twould be neat is running duel turbos.
Old May 14, 2009 | 07:10 PM
BlueBeast2's Avatar
BlueBeast2
I've never heard of putting an X or H pipe on a truck. Now if we were talking Mustangs
