To Lift or not to Lift
Old May 13, 2009 | 11:22 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Don't be a viper!!!
Old May 13, 2009 | 12:07 PM
97black_ram's Avatar
97black_ram
Originally Posted by dodge15004x45.9
Don't be a viper!!!
Was that intended for me? I'm not sure who viper is, other than the name being mentioned on the Duct tape thread right now.
I was just suggesting a mod that I did a year back when I wanted to lift the front of my 2wd and put a better set of coils in since they were shot.
Old May 13, 2009 | 12:24 PM
dodgeram07's Avatar
dodgeram07
Don't be a viper!!!
a snake??
oh 97black_ram dont worry about dodge15004x45.9 he wasn't talking about you just a guy that had been on the forum for a while and about the boot, the only thing that dodge15004x45.9 will go is steal you sig
back to the topic
if you are only lifting to 2 in i would get longer schocks, you don't have to but it will ride better
http://store.fatbobsgarage.com/share...t=products.asp
or this may work, http://store.summitracing.com/partde...5&autoview=sku
Old May 13, 2009 | 12:35 PM
dsertdog56's Avatar
dsertdog56
If I am not mistaken, Theres a complete 3 inch lift that will allow 33 inch tires to fit with the proper rims. It might have been Pro Comp. Your truck will sit as high as a stock 4wd ram with 285's on it.
Someone also makes/made a huge 6 inch lift for these trucks. That one you'll have to research and it comes with different spindles and control arms. The truck truly looks like a 4by with that. I have seen one of these lifted trucks in Phoenix and it fooled me.
The Viper comment was totaly uncool, unwarranted, and uncalled for...
Old May 13, 2009 | 01:13 PM
EndIsNear's Avatar
EndIsNear
Yea, Fabtech make's a 6.5" Ultimate Lift, a 3" Coil and Arm lift, and a 3.5" Spindle Lift, all for a 2WD. Doetsch-Shocks makes a 2", 3", 4" 5" and 6" lift. They use the same principles as Fabtech, but Fabtech has been the known and trusted brand throughout the forum. They are considerably higher in price though. And then the all known body lift, although they don;t always look good on a 2WD without a proper suspension lift to accomodate it. I've been researching this myself.
For a spring spacer, it's very simple. Just takes a few hours. I installed a 1.5" spacer, and want to add another 3", just to give it that 4WD look. So, I guess I'm a poser as well!
Check out:
www.fabtechmotorsports.com
www.doetsch-shocks.com
Edit: Check this out. This is a 2001 2WD with a 6.5" Suspension and 3" body lift.
http://images.google.com/imgres?imgu...3D288%26um%3D1
Old May 13, 2009 | 02:06 PM
Mowhawk's Avatar
Mowhawk
Originally Posted by Rebhays27
That's what I was hoping to hear. How hard is it to install a 2" suspension lift kit I'm not an ace mechanic but I'm not afraid to try any repair as long as I can undo any screw ups. You think I'll get sand kicked in my face at the 4WD rally's if I'm discovered (Poser)
MowHawk, I was looking at the photo why do you choose the 2 piece door vent viser as opposed to the 4 piece?
Thanks
Was on the truck when i bought it. It works so, i kept lol
Old May 13, 2009 | 02:43 PM
dakotas ram's Avatar
dakotas ram
what do you plan on doing with your truck? mainly for looks? or you gonna be catching some air?
Viper put a 2" coil spacer up front and he had to grind something and install limit straps b/c when extended it was hitting somewhere, but hes from socal so i believe its only cause he was catchin air......
you can get a 3" bodylift for around $200 from summit...hers some other options
http://cgi.ebay.com/ebaymotors/94-01...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Dodge...Q5fAccessories
http://cgi.ebay.com/ebaymotors/DODGE...Q5fAccessories
Old May 13, 2009 | 02:50 PM
dodge15004x45.9
Originally Posted by dodgeram07
a snake??
back to the topic
Thank you dodgeram07! I still have yr sing i need to change it but I can't find out how.
Old May 14, 2009 | 12:32 AM
Sheriff420's Avatar
Sheriff420
you may need longer brake lines with a 2 inch lift, one post on here recently said that the 2 inch leveling kit said you don't need them but the guy had his axle extend all the way down and popped the brake lines off. also keep in mind that bigger tires = lower mpg.
Old May 14, 2009 | 10:04 PM
Rebhays27's Avatar
Rebhays27
I jus mainly want the looks I really like the look of the 4X4 and mine hasn't grown into one yet I'm begining to believe it isn't going to
