strange air or hissing noise ? ?
Old Mar 13, 2005 | 12:11 AM
macsnjets's Avatar
macsnjets
Default strange air or hissing noise ? ?
I know I've read posts relating to this but I couldn't find them with a search. I get a air noise under moderate acceleration until the engine rpm catches up with throttle position. It almost sounds like a turbo charger or an air leak or maybe even the fuel just pissin' down the intake (we all know it does that) . I would think any kind of air leak would give a check eng lite but I thought I read about something leaking before the intake manifold. Does anybody know the noise I'm talking about ? What the $#&* is it and how to fix ?
Thanks
Old Mar 13, 2005 | 10:19 AM
bamory's Avatar
bamory
Default RE: strange air or hissing noise ? ?
Pull you airbox on your TB should be a gasket sitting on top of TB-probably gone, I had the same problem and replaced it 1.99 Autozone and now its completely gone, some people had me ready to tear my top end off, but with the plenum gasket you will have other symptoms, popping etc etc,
Old Mar 14, 2005 | 10:25 PM
CousinLk's Avatar
CousinLk
I don't know how to fix it but I have it too and have been wondering the same things as you... if you've learned anything about this please let me know... it's driving me crazy
Old Mar 14, 2005 | 10:33 PM
CousinLk's Avatar
CousinLk
What is a TB? I'm sorry but I am new to all this and need to try to understand all this
Old Mar 14, 2005 | 11:05 PM
bamory's Avatar
bamory
If you pull the airbox on top of what used to be called a carb you will be able to put a gasket on top of there, flat against the top of the Throttle Body TB and then the put the box back on.....If thats hard to follow just go to Autozone and they will replace it for you
Old Mar 14, 2005 | 11:18 PM
CousinLk's Avatar
CousinLk
Thank you very much for the info, I'm an old gal what do I know....lol, but I dearly love my 1998 Dodge Ram Quad Cab.... I've only had it two weeks this wednesday 3/16/05 and am learning
Old Mar 15, 2005 | 05:53 PM
mxmancr250's Avatar
mxmancr250
You might want to check and make sure there isn't a snake in there. They like the heat and whenever you rev up the engine it freaks them out and they start hissing like crazy!
Old Mar 15, 2005 | 05:58 PM
QUICK_SILVER's Avatar
QUICK_SILVER
[sm=alcoholic.gif] I have a hissing sound too![sm=wootwoot.gif]
[sm=gears.gif]
.......[sm=gobble.gif]
Quick
Old Mar 15, 2005 | 07:01 PM
steve05ram360's Avatar
steve05ram360
while your in there, take a torque wrench to the throttle body mounting bolts and make sure they're still torqued down to the proper spec. if you don't have a torque wrench, open end wrench tight will work just the same... just don't go HULK on it.
Old Mar 15, 2005 | 11:57 PM
macsnjets's Avatar
macsnjets
Well I finally got a chance to pop open the hood. It looks like someone didn't close the airbox correctly not to mention the clamp was a bit loose however now that its all back together correctly I still get just a small hiss under moderate acceleration. Its much better than it was but should it be totally quiet ?
