Compression problem
Old May 14, 2009 | 09:33 PM
Erik Kuijvenhoven's Avatar
Erik Kuijvenhoven
Default Compression problem
Hey guys I got a huge compression prob in my #8 (firing order) Cylinder If u remember that piece of ceramic that was lodged into my engine was in my #7 on the opposite side of the engine the #8 is reading 60PSI or 55PSI and the others are at 180PSI (after 6 cranks with a COLD engine) what do u think could be fu**t will she run for a while???? I am seeing a power loss and she idles funny and she is shaking under low rpm in every gear................ Now what do u think ?????????? Thanks allot I appreciate the input
Old May 14, 2009 | 10:08 PM
97black_ram's Avatar
97black_ram
Well I followed your other thread. I would do what Purpl suggested with a air compressor and the leak down test. It is either a valve not seating, blown head gasket, piston ring fried or head cracked.
And yes the engine will run like crap with only 7 good cylinders.
Old May 14, 2009 | 10:25 PM
dhvaughan's Avatar
dhvaughan
^yes. a head job is in your future.
Old May 14, 2009 | 11:06 PM
Erik Kuijvenhoven
so a head job means a total F**N engine rebuild basically
so i might as well say a used engine because its 500 bucks cheaper GGGGGRRRRRRRRRRRRRRR or do u guys think I can find someone to trow some new rings and hone the cylinder and re surface the head ect... for less than 1200 Canadian????? How long or can I drive like this for a bit ??? or tow my trailer on one cylinder with 50psi????? running compression????????
Old May 14, 2009 | 11:17 PM
97black_ram
so i might aswell say a used engine is 500 bucks cheaper GGGGGRRRRRRRRRRRRRRR
NO!! Just the top end. I have already done this and will do again, don't ask.
I would say if your just pulling the heads and changing a gasket maybe $100, but I would suggest finding a machine shop and have them go over it end to end and get it machined flat, then your looking at still less than $500.
Remember I said don't ask, well this is what I have to do as well because I skipped the machine shop step. Will be the second time I pull the heads.
They are easy but very time consuming.
Old May 14, 2009 | 11:30 PM
Erik Kuijvenhoven
U thing my head gasket could make just one cylinder have Messed up compression????? so the best way is this compressor test eh can my local mechanic do it for my is it a common test to be done to preoblem solve this kinda thing ??? THANKS for all the input so far
Old May 14, 2009 | 11:37 PM
97black_ram
Anythings possible. If your local mechanic doesn't bend you over for money, than yes he should be able to. And its another way to check the cylinder health if you will.
I wouldn't get another engine, because you could buy one in worse condition. Stick with what you have.
Old May 14, 2009 | 11:39 PM
Erik Kuijvenhoven
Thansk for the info hopefully its something 600 or less
Old May 14, 2009 | 11:41 PM
97black_ram
Definitely less than that. For that kind of money you could build that engine up into a real beast.
Old May 14, 2009 | 11:49 PM
Erik Kuijvenhoven
so can i drive / tow like this or am i gonna do more damge ????
