torque converter fluid change
Old May 20, 2009 | 10:58 PM
BigRedRam95's Avatar
BigRedRam95
Default torque converter fluid change
Have any of you guys ever changed the fluid in your torque converter. Do you have to drop the trans or is there a inspecton plate. I have a 95 and have never done it sence I got it in nov of 2008. Thanks for the help
Old May 20, 2009 | 11:23 PM
dhvaughan's Avatar
dhvaughan
you'd have to either flush the transmission, or pull it out and remove the tc. its not worth the trouble. just drain, replace filter, and refill about every 12-24k and it'll take care of it. that replaces about 1/2 - 2/3 of the fluid.
if your fluid is really nasty then change it twice, about a week or two or three apart.
Old May 20, 2009 | 11:44 PM
BigRedRam95
I did replace the filter and refilled truck only has 70,000 the day I got the truck I took it to advance auto parts and thay told me that the trans where dad in that year dodge rams. so thay gave me some sea foam told me to drive it for 10 miles and change the fluid. so I did and have had no problem. I should change the fluid in the T-case, and front and rear diff to.
Old May 21, 2009 | 12:10 AM
dhvaughan's Avatar
dhvaughan
you put seafoam in the transmission? why in the holy hell would you do that? don't do that and stop taking advice from people at advance or autozone. they may or may not know what they're talking about. and yes dodge transmissions suck, but seafoam won't fix them...
do a transmission service again sometime soon and use ATF+4 in transmission and t-case. use any 90W in front/rear diffs.
Old May 21, 2009 | 12:45 AM
J415's Avatar
J415
I believe sea foam makes a transmission additive.
Old May 21, 2009 | 06:37 AM
BigRedRam95
Your right thay do that is what I put in. I drove it for 10 miles and then changed the fluid.
Old May 21, 2009 | 07:03 AM
dhvaughan's Avatar
dhvaughan
oops. i thought you put engine seafoam in it.
i still recommend NO additives in trans. ATF+4 is the best and only thing you should put in it. anything else makes things worse.
Old May 21, 2009 | 08:51 AM
aim4squirrels's Avatar
aim4squirrels
that seafoam trans tune isn't a good idea either.
I sure it's great for a tranny that uses type F fluid, but not in a full syn.
Old May 21, 2009 | 10:36 AM
Linustratus's Avatar
Linustratus
I think its totally worth the bucks and peace of mind getting the flush done..........
Old May 21, 2009 | 10:37 AM
Linustratus
And save yourself the bucks and bring your own ATF. Shop markup on that stuff isnt pretty!
