94 ram 1500
Old May 21, 2009 | 08:29 AM
robbiehindman's Avatar
robbiehindman
Default 94 ram 1500
im wanting to read the ses light myself, what type of computer does this truck have, i have an obd1 cable for a 94 trans am, is the 94 dodge truck an obd1 computer?
Old May 21, 2009 | 05:54 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yes... but back then the plugs were different for different make vehicles. So chances are it wont work.
Old May 21, 2009 | 07:07 PM
dakotas ram's Avatar
dakotas ram
you can read the code without one......turn your key on and off 3 times fast.....check engine light will come on then go off.......then it will flash so many times then pause, then flash again.....that will give you a 2 digit code.....it can flash more than one code also and at the end it flashes 55 i believe......if youre unsure of the #, do it again....it can get confusing keeping up with the flashes....when youre done, unhook your battery and try to start the truck for 30sec or so to clear them
