How much Weight can I get in the bed?
Old 05-22-2009, 11:07 PM
Hahns5.2's Avatar
Hahns5.2
Hahns5.2 is offline
Originally Posted by Sheriff420
ram 1500 is 1000lbs, ram 2500 is 1500lbs and ram 3500 is 2000lbs.
Maybe 40 years ago when the term "half ton", "3/4 ton" or "one ton" actually meant something.
Even my Dakota is rated for 2K in the bed.
  #22
Old 05-22-2009, 11:29 PM
hutch1973's Avatar
hutch1973
hutch1973 is offline
Those numbers can't be right, where are they from? I know the 2001 specs for a quad cab short bed 4x4 are 1500-1380lbs, 2500-2980lbs, 3500-4900lbs. No way is the payload for a 3/4 ton or 1 ton that low. Don't know why the payloads would be significantly different for 2nd gens.
  #23
Old 05-23-2009, 01:02 AM
95MaroonMonster's Avatar
95MaroonMonster
95MaroonMonster is offline
idk about actual weight, but ive had 3 buckets from a bobcat skidsteer, along with 400 lbs of fuel in a tank in the bed, drove it 15 or so miles just fine, but it sure squatted me down, even with 8 springs in the rear packs
  #24
Old 05-23-2009, 08:28 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
i was just saying what i thought i knew, i thought 1/2 ton meant that you could put 1/2 ton in the bed and 3/4 meant you could put 3/4 ton in the bed and 1 ton meant you could put 1 ton in the bed. but maybe i'm wrong, but then again if you put more than 1/2 ton in a 1500 the handling and braking are less than optimum. looking at this post though, i don't think any of us actually pay attention to the load ratings. if it'll fit in the bed, its going in the bed.
Originally Posted by THEGOLDPRO
i put 4 yards of mulch in my truck last month, it weighed just over 3k pounds, truck didnt squat too too bad, i have put alot more weight in it in the past, i have no idea what my 8 foot sander loaded down with salt/sand weighs prolly close to 5k.
this pic makes it look liike its sagging more then it is, it was in a hole when i parked.
i want the red one!
  #25
Old 05-23-2009, 09:42 AM
hutch1973's Avatar
hutch1973
Ahhh, ok. I plan on putting some helper springs or otherwise in the back of mine before I put that much in it again. I didn't realize I had that much weight in the back until i saw it squat.
  #26
Old 05-23-2009, 10:20 AM
mopar1973man's Avatar
mopar1973man
mopar1973man is offline
Go big or go home... Naw... Just go home big...
Doing good here...
  #27
Old 05-23-2009, 12:38 PM
hutch1973's Avatar
hutch1973
I'm sore just thinking of unloading that.
  #28
Old 05-23-2009, 02:20 PM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
Turn the od off and try to load the head of the bed heavy. That way it will help the rear from bouncing.
  #29
Old 05-23-2009, 02:24 PM
dodge15004x45.9
Doing good here...
Is that red oak I see in there. And a red light??
  #30
Old 05-23-2009, 02:39 PM
THEGOLDPRO's Avatar
THEGOLDPRO
THEGOLDPRO is offline
Doing good here...
lol i dunno if id trust those side rails to hold that weight in. and it looks like you got an add a leaf or 2 in there??
Quick Reply: How much Weight can I get in the bed?
