Wouldnt the output speed sensor afftect 1st and 2nd also? Just curious im dealing with slipping when it tries and shift 3rd and 4th setting off codes, just replaced the electronic part and the entire vavlebody assy. From an RFE that was supposedly pulled out of a wrecked running driving vehicle not sure which exactly. Before i did that it had no gear at all and set off 4 codes..
