lifter or lifters taping?
Old May 25, 2009 | 06:25 PM
working4ev's Avatar
working4ev
there is no effect on power or how the engine runs just this dam tap tap. I will try running some cleaner throw at the next fill up $$.
I was thinking valves but the sound is the same at all RPMs if it was the valves wouldn't it change with the RPM?
Old May 25, 2009 | 06:41 PM
lv360ram's Avatar
lv360ram
could you hold the camera close to the center of the valve cover and rev the engine gradually to 2000rpm and post another video?
Old May 26, 2009 | 12:54 AM
speeddemon31176's Avatar
speeddemon31176
If the sound doesn't change throughout the rpm range then I would say injectors for sure, but another video with changing rpm levels would definitely help like LV said.
Old Jul 13, 2009 | 08:45 AM
charlie1935's Avatar
charlie1935
The injectors function in direct relation to RPM just like valve train components.
Old Jul 13, 2009 | 12:11 PM
notanexit7's Avatar
notanexit7
so what does it mean when you hear a similar ticking noise only when accelerating???
Old Jul 13, 2009 | 01:37 PM
PurplDodge's Avatar
PurplDodge
Pinging.
Old Jul 13, 2009 | 05:15 PM
notanexit7's Avatar
notanexit7
Originally Posted by PurplDodge
Pinging.
better not be, engine was rebuilt 4k miles ago and it was doing it then
Old Jul 13, 2009 | 05:24 PM
PurplDodge's Avatar
PurplDodge
Is your plenum leaking?
Old Jul 13, 2009 | 08:57 PM
dodge15004x45.9's Avatar
dodge15004x45.9
I would say yes if it is pining.
Old Jul 13, 2009 | 11:01 PM
notanexit7's Avatar
notanexit7
it's not a pinging noise it sounds almost like that guy's video but only when i press the pedal. and the plenum is brand new, i watched the guy put it back together.
