what is this noise (video)
Old Jun 22, 2009 | 08:42 PM
  #21
dodge15004x45.9's Avatar
dodge15004x45.9
Originally Posted by busaguy05
Are you talking about the zerk fitting?
IDK. I had them replaced and the gut told me tht i need a special fitting to grease them.
Old Jun 22, 2009 | 10:51 PM
  #22
aim4squirrels's Avatar
aim4squirrels
Originally Posted by zman17
If you used Cyclo, you would not have had to use a pipe on the breaker bar, lol
nevermind him, he's been huffing again.
Old Jun 23, 2009 | 10:55 AM
  #23
Sheriff420's Avatar
Sheriff420
i got the brute force u joint. hopefully it'll hold up, but if it doesn't then i'll just change it again. now that i've done it i see that it isn't as bad as people hype it up to be.
Old Aug 15, 2009 | 01:02 PM
  #24
peterfromme's Avatar
peterfromme
Thanks everyone for the help. I watched the video that Sheriff posted and that is EXACTLY like what I heard. I guess I'm looking at doing U-Joints.
Old Aug 15, 2009 | 02:18 PM
  #25
Sheriff420's Avatar
Sheriff420
its not a bad idea to change them both out if you've never done it before. i thought my passenger side was still good because it was nice and tight but when i pulled both axles out to change the driver axle seal i found out that the passenger u joint was seized up a little bit due to lack of grease. all together it should cost you about 40$ to do them both if you already have the hub nut socket. if you don't then it should cost about 60 because you'll need a 1 11/16" socket and a 3/4" drive breaker bar.
