metal in my cylinder
Old Aug 14, 2009 | 04:22 PM
Joey Buentello's Avatar
Joey Buentello
Default metal in my cylinder
Broken piece of center punch in my #3 cylinder trying to remove it with a small magnet. Any ideas, don't wanna rebuild.
Old Aug 14, 2009 | 04:37 PM
wjxavier's Avatar
wjxavier
if the magnet doesnt work, you could try mechanical fingers. or take a piece of duck tape or something and wrap it around like a pen or something and try to stick it to the piece of center punch (kinda like the gum on a stick trick, except no gum, and no stick lol).
Old Aug 14, 2009 | 04:54 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Tie a string around the magnet and drop it in.
Old Aug 15, 2009 | 12:43 AM
dakotas ram's Avatar
dakotas ram
thatll stick to the side......
im guessing this is done thru your plug hole? how big of a piece is it?
maybe turn your motor over by hand to bring it closer to the top
Old Aug 15, 2009 | 01:16 AM
Ram15002ndGen's Avatar
Ram15002ndGen
Use one of those magnetic pick up tools. Yea, it will stick to the sides, but you can push it in and one it grabs just pull it back out slowly. My pick up magnet (Craftsman) is cylindrical and slender, so it would fit in there.
Old Aug 15, 2009 | 01:18 AM
95MaroonMonster's Avatar
95MaroonMonster
eh, if nothing else take the head off, major pain in the *** for a piece of center punch though
Old Aug 15, 2009 | 09:10 AM
palerider9999's Avatar
palerider9999
How about a shop vac using the spark plug hole with the valves open? Just make sure the vac is empty and check it to be sure you were successful.
Old Aug 15, 2009 | 10:42 AM
Sheriff420's Avatar
Sheriff420
if that thing gets wedged between the cylinder and the cylinder wall it could do some scratching and that wouldn't be good.
Old Aug 15, 2009 | 11:02 AM
dhvaughan's Avatar
dhvaughan
i'd recommend a piece of wire, with a few rounds of very sticky duct tape, about 1" long, wrapped around the end, sticky side out. use the good, super sticky duct tape, not the cheap stuff. make sure it will stay on the wire and doesn't just fall off. bend a slight curve in the wire and poke it in and "go bottom fishing".
Old Aug 15, 2009 | 11:03 AM
Joey Buentello
I've tried a magnetic pick up tool, and a shop vac, didn't work. And yes this is through the plug hole.
