my 95 ram 1500 has steerin problems?!?!?!?!?
Old May 24, 2009 | 09:27 PM
flaboy42001's Avatar
flaboy42001
Unhappy my 95 ram 1500 has steerin problems?!?!?!?!?
my 95 ram 1500 the steering is really lose and need intake on how to fix or some help on it please and thanks
Old May 24, 2009 | 09:38 PM
zman17's Avatar
zman17
Retired Moderator - RIP
First of all we need to know if it is 2 or 4wd.
Old May 24, 2009 | 10:06 PM
flaboy42001
its 4wd now
Old May 24, 2009 | 10:08 PM
97black_ram's Avatar
97black_ram
Exactly what do you mean by loose? There's play in the steering wheel or play in the steering linkages under the truck.
If it's in the steering wheel there's a little screw you can turn in to tighten it up and take the play out.
Old May 24, 2009 | 10:10 PM
flaboy42001
like when i go to turn the steering wheel turns almost a full turn before the tires start turning
Old May 24, 2009 | 10:27 PM
97black_ram
I would have someone turn the wheel while your under the truck and see what's going on. Well the little adjustment screw on the p/s gear box probably won't take up that much play. I'm thinking the gear box is shot, but don't my word for it.
Old May 24, 2009 | 11:08 PM
speeddemon31176's Avatar
speeddemon31176
^+1 on the box being shot. I tried adjusting mine but am in the same boat. There just isn't enough adjustment to take up the play in mine. I would also suggest having someone turn the wheel back and forth while you go over all your steering joints. Could be more than just the box that is bad.
Old May 25, 2009 | 12:43 AM
flaboy42001
thanks yall im gonna try it tomorow and see what happens
