RPM's While Towing
Old May 26, 2009 | 09:20 PM
97black_ram's Avatar
97black_ram
Originally Posted by dhvaughan
^no, no, no...
t-stat keeps an engine at hot temp (180-195) by partially closing and restricting or blocking coolant flow.
no t-stat allows it to cool to its maximum potential.
i think 4k is a little high. that seems likes its one gear too low.
Ok, cool. 4k in 2nd and cruises at about 2400 in third.
Old May 26, 2009 | 09:40 PM
95MaroonMonster's Avatar
95MaroonMonster
2400 at what RPM, i got bout 2250 at 55 with OD out
pulls the jeep like is a paper weight, compared to what else i pull
Old May 26, 2009 | 09:43 PM
97black_ram
I'm running 65-70 pulling a 7k trailer with o/d out at about 2400 rpms until I hit a 15% grade then it shifts into 2nd and run about 4k rpms until i hit the top.
Old May 26, 2009 | 10:05 PM
95MaroonMonster
yea 2400 sounds bout right at that speed, seeing as you have the same 3.55 gears that i do and mine runs bout the same
with od on in at just over 1500 going 55 and up to 2000 goin 70
