temp question
Old 05-29-2009 | 07:27 AM
wesley11's Avatar
wesley11
The t-stat must be opening to get to 200 and stay. Thinking about replacing the radiator. Will flush first. To reverse flush do I just stick a hose in the oposite derection of flow? Thanks again
  #22
Old 05-29-2009 | 10:20 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Dude get a new t stat as well you have to take that hose off to get all the old fluid out.
  #23
Old 05-29-2009 | 11:01 PM
J415's Avatar
J415
Originally Posted by Laramie1997
Not usually, Those either fail closed causing you over heat. Unless you installed a fail safe which in case of a problem, will fail in the open position.
Don't let VWandDodge catch you saying that thermostats fail closed, you'll get chewed out by him to no ends about how that never happens!!! Just busting your chops VW! don't take it seriously.
  #24
Old 05-29-2009 | 11:19 PM
Laramie1997's Avatar
Laramie1997
I dont worry about V-Dub. He is an okie...
And I never said all of them fail closed
Quick Reply: temp question
