stage 8 locking bolts
Old May 27, 2009 | 04:41 PM
lastrights's Avatar
lastrights
Default stage 8 locking bolts
im getting headers and wondering if these are ok, or if you guys know of anything better http://store.summitracing.com/partde...=KeywordSearch
Old May 27, 2009 | 04:47 PM
95MaroonMonster's Avatar
95MaroonMonster
not kidding, i just saw those advertised on 2 guys garage, or Truck U today
Old May 27, 2009 | 05:45 PM
pcfixerpro's Avatar
pcfixerpro
I used stage 8's on my headers. They seem more expensive than what they should be (you'll see what i mean when you get them.) They do the trick so I guess they are worth it. 6month and smooth sailing with my headers.
Old May 27, 2009 | 05:57 PM
lastrights's Avatar
lastrights
thanks, yeah i just dont want to be always tighting them and getting leaks and ending up getting blown gaskets :/
Old May 27, 2009 | 06:19 PM
BlueBeast2's Avatar
BlueBeast2
They are the best thing to buy for headers. I don't care what pc says. I wouldn't do headers without them
Old May 27, 2009 | 06:52 PM
Mowhawk's Avatar
Mowhawk
^ agreed. Best thing i did for my headers.
Old May 27, 2009 | 08:47 PM
pcfixerpro's Avatar
pcfixerpro
I wouldn't want to either... but just saying for the 8 bolts and some aluminum teardrop don't equal what they should cost in my opinion. Thats all. That said.... the other options arn't much different in price. If I had to do it all over again, I'd look into a set of percy's header bolts.
http://store.summitracing.com/partde...6&autoview=sku
The reason? well with the stage 8's, you have to get the bolt perfectly aligned to put the teardrop on and it should rest on the pipe so the bolts cant physically back out. Well that means some might be tightened more than others just to make the tear drop work for that bolt. Your not going to say... oh well the teardrop almost fits if i back the bolt out a hair. Instead you tighen it down more to make it work. With these you tighen the bolts down as tight as needed, then use an allen head wrench to spred the bolt. That means all are equally tightened, and theoretically should work equivelent to the stage 8's. Oh, I shouldn't forget to mention that a few of the teardrops will need to be modified to fit so it isn't even completely bolt on and go for our trucks. I had to grind four or so down. While it really isn't a big deal, it is something else to mention about the stage 8's. Let me know what you end up getting.
Old May 27, 2009 | 11:45 PM
lastrights's Avatar
lastrights
well i just picked up pacesetter lontubes for 140 buck on ebay, so im really excited to get them on , thanks for your guys help , im sure i will have more questions , i order new gaskets and stage 8 locking bolts also !!
Old May 28, 2009 | 12:06 AM
BigDodge99's Avatar
BigDodge99
I have used them for a few years and they are a pain. Had to modify them to fit and I still had leaks and blown gaskets. Wait till you try to take a clip off and it goes flying across the garage! FUN! I wont buy them again. In my opinion they didnt work very well. What pcfixerpro said about them is all very true! I will try the percys next time.
Old May 28, 2009 | 12:14 AM
BlueBeast2's Avatar
BlueBeast2
If you go easy on them and use pliers you won't have a problem getting them off. Also if you get good gaskets you shouldn't have a problem
