How do you reset the PCM?
Old May 31, 2009 | 10:23 AM
  #31
dhvaughan's Avatar
dhvaughan
Originally Posted by Sheriff420
the fuel disconnect tool (provided its the right size) just closes over the line and you push it into the female end of the connection, there are spring loaded keepers in the connection and the tool separates them from the lip at the end of the male line so it can slide off.
^ yes. if it still doesn't separate, squirt some wd40 or pb-blaster up in there and then with the disconnect tool inserted, twist it back and forth a little. in other words, lube the female end a little bit.
Old May 31, 2009 | 10:30 AM
  #32
aim4squirrels's Avatar
aim4squirrels
Originally Posted by Laramie1997
And to the others, watch your step. Neon is still cruising this forum, he just annoys the 3rd gen guys now. Also, he got a name change too....
Yes, but the block I have on him still transferred over when he changed. Why would anyone worry about what he thinks? He never bothered to care what anyone else thinks...It's a done topic at this point though, I'll be sure to skip over the 3rd gens when I purchase a new truck.
Oh and I never had much luck with the super cheapo plastic circular disconnect tools, the sleeve on them wasn't long or thick enough to depress the clips on some parts. The metal ones from Harbor Freight work much better IMO.
Old May 31, 2009 | 10:32 AM
  #33
zman17's Avatar
zman17
Retired Moderator - RIP
That would only apply if the female end is 30 + years old, (as in 1st generation) and they don't have quick disconnects. No lube is required for newer models. However it might make pulling it out easier.
