Valve stem seals
Old May 30, 2009 | 02:05 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by ICEMAN_CH
This is exactly why I posted. I was a little nervous about using air. The rope idea is a great idea. I really don't want to take the heads off.
Does anyone have an idea on how to clean the cylinder?
After you fix it you can use Seafoam, Techron or the Mopar stuff and it will clean itself out.
Old May 30, 2009 | 02:09 PM
SEAL's Avatar
SEAL
Iceman
That hollow sound and the gunk tells me that you have a cylinder not firing. Could be a bad plug or a wire. I would make sure the plug was firing before you go any farther. If it was a stem seal and the plug was still firing you would not see gunk in the cylinder as it would just burn the oil that entered. If you are using that much oil and have no external leaks, the stem seals may need replacing but I don't believe that is the gunk problem. As far as cleaning the cylinder don't worry about it. It should take care of itself once the cylinder is firing again.
While you have the plug out do a compression check on that cylinder just to rule out broken rings or a hole in the piston.
Old May 30, 2009 | 02:38 PM
zman17's Avatar
zman17
If the plug wasn't firing he would most likely have a cel for a mis fire.
Old May 30, 2009 | 10:55 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by zman17
LOL ! Good tips, but I just can't seem to get it to happen on my 98.
oh, just come down and park in the georgia sun with the windows mostly closed up and let it heat up to about 500*.
i'm so pissed off at myself over this. when i bought the truck the dash was in good shape. just 2 summers in the hot *** parking lot at work did it in. with as much publicity as there is on the ram dash, i should have known better. and if i'd just put a quilt over it to keep the direct heat off, its likely it would have stayed good.
Old May 30, 2009 | 11:38 PM
ICEMAN_CH's Avatar
ICEMAN_CH
Originally Posted by SEAL
Iceman
I don't have a cel for a misfire. Put if there was no compression I guess it could cause it to not fire the way it should. I'm not really sure what the computer looks for on a misfire. I have been having several other problems lately. I had a problem where when I started it wouldn't idle or run correctly. If I put the gas on it it would just bog down and not go anywere. After replacing every sensor on the damn thing I finally replaced the O2 sensors wich I thought fixed the problem. errrrr wrong. The problem is back it just did it today. The truck always runs rich on start up. Could oil getting into that cylinder be messing up my o2 sensors? I'm going to do a compresion test as soon as I get a chance.
Old May 30, 2009 | 11:45 PM
RamSport97's Avatar
RamSport97
Does your engine smoke on startups occasionally? That is generally one of the best signs of valve stem seals going.
Old May 31, 2009 | 12:01 AM
ICEMAN_CH's Avatar
ICEMAN_CH
No it has never smoked.
Old May 31, 2009 | 05:28 AM
zman17's Avatar
zman17
Do the compression test, and did you replace the temp sensor also? And +1 on the smoking on start up question, I'd check the plenum for the heck of it after the comp test.
Old May 31, 2009 | 08:53 AM
aim4squirrels's Avatar
aim4squirrels
Were you gonna make that quilt yourself, Vaughan?
Old May 31, 2009 | 09:04 AM
zman17's Avatar
zman17
I protect mine with dirt and dust from jobsites. LOL
