bought some fancey @$$ headlights, need help wif stuffs
Old May 30, 2009 | 06:39 PM
SAVAGECITY's Avatar
SAVAGECITY
Default bought some fancey @$$ headlights, need help wif stuffs
ok, i bought some fancey *** looking headlights. halo,L.E.D. and projectors kinda of deal, they look nice. so heres why i made this thread. instructions say "installation should take aprroximatly 1 1/2 hours" a little long but understandable then it says "an assistant may be needed when removing the bumper" thats when i thought this might be more difficult then expected. and now, what do i do to get acess to my lights
Old May 30, 2009 | 06:51 PM
aim4squirrels's Avatar
aim4squirrels
Just remove the plastic trim piece, you'll be fine. Sounds like you have the exact same set I bought. If that is the case, and after you install them and the hi-beam light and main beams don't work right, reverse the Black and Blue wire and then see if that fixes it.
You can remove the pins from the big blue quick connect harness with a very small standard screwdriver from the front of the harness. There is a tiny clip that holds the pins in place and if you push it up with the screwdriver, the pins will then slide out the back of the harness and you won't have to cut and splice wires.
Old May 30, 2009 | 07:08 PM
SAVAGECITY's Avatar
SAVAGECITY
this is where and whut i got
http://www.k2motor.com/2lhp-ram94b-tm.html
Old May 30, 2009 | 10:28 PM
lastrights's Avatar
lastrights
i put halo in my cousins 98 and we had to rewire the whole headlight
Old May 31, 2009 | 03:59 AM
speeddemon31176's Avatar
speeddemon31176
I had my headlight out the other day when I removed the fender to change it. You can get the upper two bolts out easily. The one that is kind of hidden behind the bumper can be removed with a 10 mm ratchet wrench. Once you get it loose you can wiggle the wrench free and turn the bolt out by hand.
Old May 31, 2009 | 09:30 AM
aim4squirrels
Man, those are wild! I'd like to see those lit up on install.
Old May 31, 2009 | 11:43 AM
lastrights's Avatar
lastrights
not bad on the price 139 and free shipping
Old May 31, 2009 | 04:12 PM
nathangfnd's Avatar
nathangfnd
I was just wondering are they true plug and play?
I want new head lights but dont want to have to rewire all kinds of stuff
Old May 31, 2009 | 07:47 PM
hutch1973's Avatar
hutch1973
Ditto.
Post some pics when you get them installed. If you like 'em and they work well, I'm getting a pair.
Old May 31, 2009 | 08:12 PM
SAVAGECITY's Avatar
SAVAGECITY
(salesperson voice) these babys are true plug and play)
(really fast voice at end of commercail) requires stock blinker bulb and halo and led wiring.
they leave the halo and led's so that you could either wire them to the park lights or to have them totally seprete, which is what i want but might just hook em up to the park lights
p.s. and ah, the halos and leds are not blue, i put the wires to my battery and they were white, i was bummed a little, i wanted them different then everything else
