Poor Gas Mileage & Loss of power "Solved"
Old Jun 22, 2009 | 08:48 AM
  #51
audiomechanic's Avatar
audiomechanic
Originally Posted by fastyz400
Ya, a hand full of people are reporting power increases in the dakotas & durango portions of the forum. It really helps out the magnum V8's and V6's. So, if your truck has an old map sensor, It's best just replacing it.
I'm sure replacing my O2 helped as well. I'm pretty sure it was original just like the MAP sensor. Shoot, up till this point in owning the truck, I've replace the AIC, TPS, MAP, and O2. Just gotta do the CPS, CamPS, and AIT and ALL my sensors are new!
Old Jun 22, 2009 | 05:12 PM
  #52
zman17's Avatar
zman17
Retired Moderator - RIP
I would not do the crank or cam sensors just yet. IAT and ECT might be a good idea. I would however remove the crank sensor and clean the end of it , and maybe stick a small round wire brush in the hole and have someone crank the motor over and clean the tone ring a little.
As far as the MAP goes, I have not been on the highway yet, but besides not seeing any bottom end gains, I have noticed one thing. Recently in the morning it has been taking 3 or 4 more cranks to start, and the rest of the day it would start right up. So I figured the fuel pressure regulator was going bad again. (Damn Carter fuel pump) But, since I installed the new MAP, it starts instantly every morning now. So that's a positive note on the $80 spent. We'll see if there are any other highway and MPG improvements later this week or next.
Just don't want anyone getting the wrong idea about some miracle fix and spending 80 bucks for nothing, you still need a fuel pressure tester and check the regulator on the fuel pump.
Old Jun 30, 2009 | 05:56 PM
  #53
audiomechanic
My apologies to all who were waiting for my results.
Ok, to sum it up, power is much better. The truck is no longer a pig after it warms up. It has that "just started" power to it all the time. Still sucks on the highway, but that's due to the awful 46RE that is unfortunately behind my beloved Magnum.
Gas mileage: since replacing the O2 sensor and MAP sensor, my gas mileage has increased by exactly 0 MPG. It is exactly the same.
At least I have more power. So it wasn't all bad.
Old Mar 19, 2010 | 05:07 PM
  #54
lairbear2000's Avatar
lairbear2000
Default Map Sensor 5.9L
What was the elevation when these voltages were taken?
Mine is at 4150 feet where I live.
Thanks,
Lairbear
Old Mar 24, 2010 | 01:56 PM
  #55
Nando Vazquez's Avatar
Nando Vazquez
I just recently checked at Autozone for a MAP sensor that would fit a 1999 5.2L 318 Magnum. The price for the sensor was around $96 dollars. I have found cheaper ones online buy IDK if I should trust the quality of the brand.
Old Mar 24, 2010 | 04:29 PM
  #56
dakotas ram's Avatar
dakotas ram
i bought one online for like $50 ....its a STANDARD brand and made in usa....didnt really notice and change tho
Old Mar 24, 2010 | 06:26 PM
  #57
Maxx_Magnum's Avatar
Maxx_Magnum
hmmmm.... another thing to add to the 'change it when I do the plenum' list perhaps?
That's turnin into a pretty long list
Old Mar 24, 2010 | 09:20 PM
  #58
2001Ram's Avatar
2001Ram
Even if it goes bad it wont throw a CEL or anything?
Old Mar 24, 2010 | 11:17 PM
  #59
dakotas ram
supposedly, the diaphram just hardens, so it doesnt tchnically "go bad" it just doesnt give the best reading
Old Mar 24, 2010 | 11:34 PM
  #60
CPTAFW163's Avatar
CPTAFW163
THat's funny. I had to replace everything you listed when I had a fire in my engine compartment of my 1996. After that fire and me fixing the truck...it performed much better. But that cost me about 500 for all those sensors.
I will be cleaning my TPS this weekend.
