When to use 5th gear?
Old Jun 8, 2009 | 10:39 PM
1994ram1500's Avatar
1994ram1500
Question When to use 5th gear?
Fellow NV3500 5-speed owners,
When do you all use overdrive 5th gear? I drive (Daily) a [fairly] hilly country 60mph highway here in NW missouri. I almost Always use 5th gear on this rd but i thought i might ask if i am actually hurting my gas mileage. On the hills i can feel my engine (318) bogging down and lugging, sometimes losing some speed, and i have to give it a lot more throttle in order to maintain a decent speed, but i still often sing to around 55mph on the longer hills. My question is would it be better for me to use the 1:1 ratio of 4th gear and not make my engine struggle on the hills, or use the overdrive .73:1 anyway for less rpm's. My truck is a 94 ram 1500 318, with nv3500 of course. It is a 4wd with 265 75r16's. However, i do not know the gearing and the truck is not equipped with a tachometer, so i cannot give you rpms at each gear at 60 mph. thanks for any input!
Alex
Old Jun 8, 2009 | 10:42 PM
PurplDodge's Avatar
PurplDodge
Look under your hood, right below the latch, there is a sticker that should tell you what gears you have.
Old Jun 8, 2009 | 11:17 PM
1994ram1500
unfortunately the 15 yr old sticker is practically un-readable after almost 170k miles and some overspray frome a previous re-spray
Old Jun 8, 2009 | 11:28 PM
Laramie1997's Avatar
Laramie1997
It's your personal call there. I know on our 5 speed tow truck, we will grab 4th going up a hill if it starts to bog down. That is unloaded, we will always down shift going up hill with a load on.
Old Jun 8, 2009 | 11:43 PM
PurplDodge's Avatar
PurplDodge
Haha. Mine is still readable after 171,000!
Old Jun 9, 2009 | 12:00 AM
1994ram1500
were the 2nd gen's diffs stampted with gear ratio?
