steering issue
Old Jun 10, 2009 | 06:13 PM
iowaman0322's Avatar
iowaman0322
Default steering issue
i have some play in my steering, i've replaced the steering sector,tie rods, track bar and ball joints. i'm about to replace the the intermediate shaft so my question how much should this move by twisting it when the engine is on. the knuckles are pretty rusted. the steering wheel moves as well and the both knuckles. if this is normal would this get greater while driving down the road. i have a problem with my truck wanting to go from side to side. i have a 98 dodge ram 4x4 360
Old Jun 10, 2009 | 07:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I don't know what a steering "sector" is , but I'd say you need to replace the trac bar.
Old Jun 10, 2009 | 07:36 PM
iowaman0322
steering gear box sorry not sector. i've already replaced the track bar.
Old Jun 10, 2009 | 07:58 PM
Cereal Killer's Avatar
Cereal Killer
Check these out. Maybe it'll help you.
https://dodgeforum.com/m_657750/tm.htm
https://dodgeforum.com/m_899062/tm.htm
Old Oct 16, 2009 | 08:25 PM
iowaman0322
ok well i've tried those links and adjusted the steering. nothing has changed. i'm about ready to give up it's just a pain to drive with the loose steering. only thing i can think of is the intermediate steering shaft.
Old Oct 16, 2009 | 10:27 PM
zman17's Avatar
zman17
The intermediate shaft needs to be checked for sure, it could be bad along with the gear box. If you tried the adjustment to the box and it didn't help, then the box is most likely toast.
Old Oct 16, 2009 | 11:01 PM
iowaman0322
i replaced the gear box about 4 years. could it of not been adjusted right then. how do i check the shaft or should i take it to shop.
Old Oct 17, 2009 | 08:17 AM
zman17's Avatar
zman17
Just have some one in the truck (without it running)turn the wheel left to right a couple inches, while you look at it. Pay attention to the ujoints and the slip joint. Also watch the box and see if the input shaft is twisting a lot without any pitman arm movement.
Old Oct 17, 2009 | 04:17 PM
iowaman0322
if i were to replace the shaft should i wait to get an alignment or would it matter.
Old Oct 18, 2009 | 05:50 AM
zman17's Avatar
zman17
No alignment needed, the shaft only goes on one way.
