looky what came in today!
Old Jun 10, 2009 | 06:46 PM
aim4squirrels's Avatar
aim4squirrels
Default looky what came in today!
Check it:
A 25% underdrive crank pulley from ASP. Took me literally 15 minutes to install. cost $75 + $25 for the new belt. They sent me a 6 rib belt pictured here:
The belt works but had the tensioner pulley pulled almost all the way to the tightest setting. I've talked with several knowledgeable guys that said that a 6 rib belt is fine on a 7 rib pulley system so long as the tensioner can hold tight and you set the belt all the way toward the engine side. I still got a little weirded out and went to NAPA and had them find me a 7 rib belt that was 5/8" longer than the one ASP sent. It fits almost like stock and I'm going to monitor it for stetch. The NAPA P/N on that belt is 070951.
Here's a comparison pic of the old and new pulley:
performance verdict? totally worth the $100 bucks. Like stacking a hypertech tune on top of the SCT tune. Not much, but noticable and a nice cheap upgrade.
Only concern is charging issue since I have electric fans, but I'm working on that.
Old Jun 10, 2009 | 06:52 PM
Miami_Son's Avatar
Miami_Son
What are the actual benefits to an underdrive pulley (more hp, faster acceleration, etc.) and will it affect not only the alternator, but the steering pump and A/C? What I've read doesn't exactly recommend them for a daily driver.
Old Jun 10, 2009 | 07:17 PM
Twisted Metal's Avatar
Twisted Metal
Aim, is it just the crank pulley? March offers crank and alternator pulley for roughly the same price? Minus the belt. I was debating this on for my 01 5.2, would like to hear some more feedback. Lastly, 15 mins? unbolt old, and bolt on new?
Old Jun 10, 2009 | 07:41 PM
BigRedRam95's Avatar
BigRedRam95
I got my underdrives today too. I got mine from Hughes Engines for $47.00 but did not come with a belt. They told me the stock would work but I will see.
Old Jun 10, 2009 | 07:58 PM
aim4squirrels
It underdrives ALL accessories. The A/C, PS pump, Water Pump, and Alternator will all move slower. Right now the alt is my primary concern as the cooling for the Rad and PS pump will be fine if the efans are running.
You have to be careful with alt pulleys, sometimes they sell pulleys that underdrive the alt and WP or PS pump even more.
yes it is literally remove 6 bolts and bolt on the new. 200 in/lbs. per bolt.
According to ASP, it's 6hp and 26ft/lbs torque gain.
Old Jun 10, 2009 | 08:04 PM
aim4squirrels
I want to add that the 5.9L has a different setup that costs quite a bit more. The balancer has to be included, IIRC, on the 5.9L engine.
Old Jun 10, 2009 | 09:12 PM
lv360ram's Avatar
lv360ram
aren't there supposed to be beer cans in the holes on that cooler top.
Old Jun 10, 2009 | 09:43 PM
dhvaughan's Avatar
dhvaughan
i thought you bought a new white coleman cooler with a piece of metal on top.
Old Jun 10, 2009 | 09:44 PM
dodgeram07's Avatar
dodgeram07
thanks alot for the heads up... i need a new belt so sound like a great time to up grade!!
aim,can i get a link??
Old Jun 10, 2009 | 09:46 PM
PurplDodge's Avatar
PurplDodge
Get a GoodYear Gatorback! They are at Autozone (that is the best quality thing you can buy there!)
Nice cooler....Er....Pulleys!
