plenum gasket?????
Old Jun 11, 2009 | 03:26 PM
dakotas ram's Avatar
dakotas ram
nah, its not too bad if youre fairly good with mechanics and everything goes good
Old Jun 11, 2009 | 03:36 PM
96rumbledodge's Avatar
96rumbledodge
haha i mean it cant be any harder than replacing an oil pump thats about all ive done on a dodge
after i do this will i notice it running a whole lot better?
Old Jun 11, 2009 | 04:16 PM
aim4squirrels's Avatar
aim4squirrels
give it a full day if you never done it. And get some baggies, tape and a sharpie and mark everything! A picture of each step as you go can really help you to reassemble it later.
Old Jun 11, 2009 | 04:42 PM
lastrights's Avatar
lastrights
i have 130xxx and dont have a leak any trucks on here with higher milage that never had a leak, im hoping not to have a leak till i get a airgap, but i need ankle surgery so it will be a while
Old Jun 11, 2009 | 04:56 PM
dakotas ram
IF it is leaking then yes
Old Jun 11, 2009 | 05:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And if it was leaking, have the cat tested ASAP after you fix it.
Old Jun 11, 2009 | 05:58 PM
zman17's Avatar
zman17
How did you test it? By looking down the TB or http://dodgeram.info/tsb/2000/09-05-00.htm
Old Jun 11, 2009 | 07:53 PM
mikey0469's Avatar
mikey0469
sorry to jack your thread, but how do you know you need to replace your plenum gasket? what are the symtoms with the engine running irregular? im not sure if the previous owner replaced it or not. it doesnt burn any oil. i have looked down the intake a while back to look for oil too, but nothing.
Old Jun 11, 2009 | 07:54 PM
mikey0469's Avatar
mikey0469
nm...i got the info i needed thanx
