New round aircleaner!
Old Jun 15, 2009 | 11:56 PM
  #71
96rumbledodge's Avatar
96rumbledodge
and i like stuff to be done correctly and for it to look good the only reason i say that is because i worry ill screw it up i dont like to repeat things i want it done correctly the first time you get what im saying?
Old Jun 16, 2009 | 12:02 AM
  #72
speeddemon31176's Avatar
speeddemon31176
Hey rumble, do you have a junk yard near you anywhere? If so go and take the s bolt off of a gm make blazer or jimmy and you have a pre bent bolt to install without fabbing it up. It is the right size too. I took the one off my buddies blazer and tried it. Perfect fit. You just need to get a nut to lock it in place when you get it facing in the right direction.
Old Jun 16, 2009 | 12:07 AM
  #73
96rumbledodge
good idea i was woundering the same thing i think thats whatt ill do
Old Jun 16, 2009 | 12:11 AM
  #74
speeddemon31176
I know that it is easy to make the s bolt but with your apprehensiveness in attempting it I figured that I would pass along that tid bit of info. I posed the question here the other day and then low and behold my buddy shows up here with his blazer and I just went over popped his hood and took his aircleaner apart. You should have seen the look on his face. Once he saw what I was up to he was into it then. Now I gotta find me a nice cast aluminum aircleaner assembly and put a K&N in it.
Old Jun 16, 2009 | 12:14 AM
  #75
96rumbledodge
same here only im using a AEM dry flow
  #76
95MaroonMonster's Avatar
95MaroonMonster
yea i gets it, i had a stressful day, and my nerves are shot
i usually don't try to come off as an ***, but **** happens
Old Jun 16, 2009 | 12:27 AM
  #77
BlueBeast2's Avatar
BlueBeast2
You sounded like someone else there for a second lol won't mention the name
Old Jun 16, 2009 | 12:30 AM
  #78
dodge15004x45.9's Avatar
dodge15004x45.9
Funny jinx. Craw out of the hole you in!
Old Jun 16, 2009 | 12:31 AM
  #79
96rumbledodge
i saw a nice mopar round cleaner really looked good on the motor black with machined MOPAR cut in it i cant seem to find one tho
Old Jun 16, 2009 | 01:05 AM
  #80
95MaroonMonster
Jegs has them under the Mopar Performance section in the cataloug
