another reason why i love having a truck
yes, this is yet another reason why i love having a truck: today is oil changing day for both vehicles(wife's '04 cavalier and my truck). well let me tell ya, changing the oil and especially the oil filter in a cavalier, sucks! not only is it a car so you have to jack it up to get underneath, but the oil filter is a pain! its one of those screw on cap paper things. and as i'm taking this off, i realize i dont have a big enough socket to do it with. so i take the air tube off to get leverage on it with pliers, and low and behold, i find oil pooling in the air tube and the intake. i'm assuming this isn't normal. anybody have any opinions or suggestions? any help is appreciated. thanks!
p.s. oil change/filter change was successful, just curious about the oil pooling.
I assume you are talking about the air intake tube that is connected to the maf sensor? If you are, my 95 vw cabrio has the same prob. Every so often I remove the hose and clean it out in my parts washer and then remove the MAF and use MAF sensor cleaner made by CRC (silver can) and clean it too.
It's blow by for the most part and the way it is designed, on the vw I have, there are other various hose from the engine connected to that hose, or at least near by. So they could be causing the oil to get back up there. And the reason I use the MAF sensor cleaner is so it doesn't cause any other probs. The oil can cause the MAF to go bad, been there done that.
