tranny is out
Old Jun 14, 2009 | 12:04 AM
Steel Horse's Avatar
Steel Horse
Default tranny is out
ok so i just lost 3rd 4th and reverse. weird thing is when i put it between park and reverse it pulls into drive but there is a clanking noise. but anyways i found a tranny out of a 2001 ram 4x4 5.2 but mine is a 5.9 . is it the same tranny?
Old Jun 14, 2009 | 12:15 AM
dakotas ram's Avatar
dakotas ram
should be.....look on your radiator support and the other tuck
Old Jun 14, 2009 | 08:31 AM
wjxavier's Avatar
wjxavier
when you open the hood of the donor truck, look straight up, you should be able to see a tag or something that says what transmission it has in it. 46re is what you're looking for i believe, correct me if im wrong
Old Jun 14, 2009 | 08:33 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You are correct , but it's the same regardless, no doubt about it.
Old Jun 14, 2009 | 11:39 AM
busaguy05's Avatar
busaguy05
The trany is the same, you need to keep your torque converter as one engine is internally balanced and the other is externally balanced. They weld weights on the torque converter for the externally balanced motor.
Old Jun 14, 2009 | 05:12 PM
MonteC's Avatar
MonteC
Dont reuse the old torque converter.
