The lift is here. Thanks jason! Our 2nd gen trucks the rear can with a block and pice of steel of to the side. See pick. (http://www.bc4x4.com/pr/2001/dodge/dodge-26.jpg) The lift blocks came with the same pice of steel off to the side. Does anyone see anything wrong with me cutting off the pice of steel on the new block? I will post a pick of the block when dad leaves for work. He doesn't know about the lift. Any problems with me cutting it off?
He meant piece.
Leave it there. It prevents the block from being dislodged from between the u-bolts. If you've ever seen a truck lose a block (I have) it is not pretty.
