Where did my low end go?
Old Jun 15, 2009 | 09:59 PM
  #31
95MaroonMonster's Avatar
95MaroonMonster
when i installed my 14x3, it seemed to help more past 2500 rpm, except when im towing, then the truck seems to pull much better from just above idle, but anything is better than the stock block of an intake
also when i redid my exhaust, i remove a ton of restriction by ending the system earlier, and going to a full 2.5 inch system after the Y pipe, and that also seemed to boost performance
Old Jun 15, 2009 | 11:46 PM
  #32
Mowhawk's Avatar
Mowhawk
14x3 cleaner does drop low end torque, not just the exhaust. Your flooding the engine with all of that air that cant be used as efficiently with the keg style inlet. Air to fuel ratio is off. I had the same problem until i put my sct tune back on . Still feels like a little loss at the low end but i can smoke em and such. Also, i pull hard ***** after 2500
Old Jun 16, 2009 | 02:32 AM
  #33
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by CSXfan
What should I be looking for when I unplug it?
I apologize, I wasn't meaning that as a test to see if it was partially at fault for your loss of low end.
I presented it as a test to show that yes, the MAP sensor can affect your power.
If you look at the Service Manual off of the Merry Christmas thread or the Haynes manual for our trucks, one of them (I think it was the Haynes) will give you the test procedures for the MAP.
Old Jun 16, 2009 | 10:21 AM
  #34
PurplDodge's Avatar
PurplDodge
Haynes has the test procedure for all the engine sensors.
Old Jun 16, 2009 | 11:43 AM
  #35
trucklover's Avatar
trucklover
Originally Posted by Miami_Son
"Here's the combo, previous bolt-on mods first. 50mm F&B throttle body, K&N round filter with Xtreme-style lid, Mopar plug wires/Accel coil/NGK plugs. Magnaflow 3" high flow cat/Dynomax 3" ultra-flow muffler. We just installed a set of used, unported 1.92 Mopar Performance R/T heads with a fresh valve job/seals, etc, used Crower 1.6 rockers, March steel underdrive crank pulley, Edelbrock shorty headers (still using factory y-pipe with pre-cats. Factory kegger intake, not modified, with Hughes billet plenum plate. Dyno tuned with an SCT controller."
I don't think I'd call all of that cheap OR easy.
I was just thinking he could do the cam without the other mods (heads, programmer, etc). No bigger than the cam is he could probably get away with using his Superchips, instead of the SCT. He wouldn't get as good results, but I bet it would be a lot stronger than it is now. Not to mention a lot cheaper than gears (as long as he does the work himself)! But like you said, this wouldn't be very easy so I guess this is a bad suggestion!!
Old Jun 16, 2009 | 05:59 PM
  #36
95MaroonMonster
now, this is weird, on the kenworth, it has a 5 inch factory exhaust system, and it seemed to pull better when i removed the muffler, not to mention sounded so cool
although it don't have a real problem at 380 HP
Old Jun 17, 2009 | 08:22 AM
  #37
CSXfan's Avatar
CSXfan
Ah I see, no problem. I'll test it when I get my truck back next Wednesday (its in the body shop for some rust repair)
How difficult is a cam replacement? Doesn't that require ripping down the entire top half of the engine? What would I be looking at cost wise? (not that it really matters, I have no money for this stuff anyway)
Old Jun 17, 2009 | 09:49 AM
  #38
aim4squirrels's Avatar
aim4squirrels
You should get that checked out.
Old Jun 17, 2009 | 11:08 AM
  #39
pcfixerpro's Avatar
pcfixerpro
I have no idea cost wise, but to physically replace the cam (pull old out and put new in) is a snap as long as your careful not to nick your bearings . And yes it does involve tearing down the top half of th engine.
Old Jun 17, 2009 | 11:32 AM
  #40
Miami_Son's Avatar
Miami_Son
I agree that removing/replacing a cam is not that difficult. It's all the work you have to do to get to it that is a chore and requires some expertise. Basically, it is a lot of work and expensive if you have to pay someone to do it.
