Front Suspension Question
Old Jun 17, 2009 | 08:14 AM
olyelr's Avatar
olyelr
Ok, 3/4 ton trucks were offered with dana 60/70/80's in the rear, it just depends on what the motor and the tranny setup is. Deisels with a manual got the 80's, while the 5.9 with the auto got the 60. I think the v10 and deisels with an auto got a 70.
Anyway, all the talk about the front axle has nothing to do with this thread. This guy has a two wheeler he is looking to put a 60 rear in and wants to match the front bolt pattern with the new rear.
To the OP, sorry, but I cannot help you with your question. But there are several people on this site that probably can. Good luck!
Old Jun 18, 2009 | 09:21 AM
Thefiremon's Avatar
Thefiremon
Originally Posted by Thefiremon
I just performed an engine swap on my 2001 1500 2wd from a 5.2 L to 5.9 (later convert it to a 408 when I put another 100,000 miles on it). It works wonderful with a B & G tune and some Hughes Engines performance parts.
I have aquired a Dana 60 spicer out of a 2001 2500 with the same 3.55 rear end but with disc brakes and I want to change out my axle. The problem is what options do I have about converting the front end. Can I just change out the hub and it fit or do i need to change out the knuckle and some other suspension parts so that it works. Need some Ideas thank you so much. Pictures hopefully will come soon. Still working on the engine. Placing a 14x3, long tubes, debating on a cat, with a major exhaust.
That is correct. The 2500 was a gas burner with 4 wheel antilock brakes just like my truck. It would be an definite upgrade from my 2wd drivetrain along with the fact of picking up the benefit of having 4 wheel disk brakes. The question I asked was would the eight lug hubs off of a 2500 fit on the spindle of a 1500 or what would I need to change to make it work. I want 8 bolt hubs on my 1500.
Last edited by Thefiremon; Jun 18, 2009 at 01:35 PM. Reason: put spindle instead of knuckle to promote the fact that I have a 2wd
Old Jun 18, 2009 | 11:39 AM
helms's Avatar
helms
Originally Posted by woodenhead
Maybe I am on the wrong generation forum or something. I have a 02 ram 2500. Is that 2nd gen? cuz the change never took place on the 2500 til 03.
In my 2500 02 ram (5.9 gas) the rear is dana 60 and front is 44.
Welcome, you are in the right place. i have an '02 2500, we are in fact 2nd gens..... the very last, and the very best . If you have a D44 front then you will have a light duty 2500 as all the HDs came with 60 fronts, like me
Old Jun 21, 2009 | 06:23 PM
willstruck's Avatar
willstruck
Originally Posted by 95MaroonMonster
the 2500s with the V10 or Holy Grail (Cummins) had a 70 rear, the 360s got a 60
i wouldn't mind having dana 60s on my truck, but don't want to go to the trouble of converting it
I thought my truck had a Dana 80 in the rear...
edit - now I see where someone else posted the explanation
Old Jun 22, 2009 | 12:02 AM
olyelr's Avatar
olyelr
Yep, you do, since you have a diesel with a manual tranny.
Old Jun 22, 2009 | 12:09 AM
95MaroonMonster's Avatar
95MaroonMonster
nope, you'll need the whole axle
the 9.25 is a semi floating axle
the 60/70/80 axles are full floating axles, hubs are completely different
Old Jun 22, 2009 | 12:18 AM
olyelr's Avatar
olyelr
He is completely swapping the rear axle with a 60. He wants to know what he has to do to get his front end (2 wheel drive) to have 8 bolt hubs.
Old Jun 22, 2009 | 12:24 AM
95MaroonMonster
ok, i must have read that wrong, it sounded to me like he wanted to swap the hubs on the rear over to the 9.25
