Now leaking coolant..
Old Jun 15, 2009 | 11:11 PM
heybuddy1901's Avatar
heybuddy1901
anyone have any more ideas?
this needs to be done by friday at the latest.
i guess its off to the stealership tomorrow to get a new timing cover gasket and WP gasket and oil pan gasket.
2nd time is the charm?
Old Jun 15, 2009 | 11:16 PM
speeddemon31176's Avatar
speeddemon31176
Maybe a water pump bolt leaking down the inside of the timing cover? I am just grasping at straws here. If I could see it I could figure it out but over the net through type is tough.
Old Jun 15, 2009 | 11:21 PM
heybuddy1901
after thinking it over, it really is only is 15 or so bolts to have it back down to the block/timing chain.
ill take it back apart tomorrow, and hope that i dont mess up the oil pan gasket and re-assemble.
the weird part is everything went back together ok. no binding or forcing or anything, so its just hard to see how something could have gone wrong.
Old Jun 15, 2009 | 11:28 PM
heybuddy1901
ok, so lemme ask this.
is there anything i need to know that i might be missing?
black RTV on the bottom of the timing cover where it meets the oil pan correct?
nothing special needed for re-installing the timing cover?
Old Jun 15, 2009 | 11:51 PM
speeddemon31176
Nothing I can think of other than what you have already stated.
Old Jun 16, 2009 | 01:19 AM
heybuddy1901
well lemme say this, i have 2 buddies coming over. were gonna knock this out in a night.
and that god dammed bottom of the timing cover is going to be more RTV than oilpan gasket
Old Jun 16, 2009 | 10:52 AM
sungod's Avatar
sungod
Maybe it is leaking from the coolant inlet?
Old Jun 16, 2009 | 01:22 PM
J415's Avatar
J415
I'm just shooting at the moon here, but could it be the rubber bypass hose on the top of the water pump. I've seen some on the DF that thought it was one thing leaking, then they come to find out it's the bypass hose. best of luck.
Old Jun 16, 2009 | 01:42 PM
aim4squirrels's Avatar
aim4squirrels
A couple bolts in the timing cover DO infiltrate the water jacket. Pull the bolts on the timing cover, put coolant resistant RTV on the threads and reinstall. I've also heard that Nickel Antiseize works as well.
Old Jun 16, 2009 | 07:22 PM
heybuddy1901
yes i know, this is not where it is leaking from.
it is leaking from the last oil pan bolt on the driver's side that goes through the flange on the timing cover. the timing cover is threaded and the bolt goes through it, completely, you can see the end of it if you open the hood and look carefully
