Help abs dashlight??
Old Jun 16, 2009 | 06:09 AM
AKZEP69's Avatar
AKZEP69
Default Help abs dashlight??
01 ram 1500 4x4 off road ed.
The abs light, along with the warning chime (bell) on dash randomly comes on... At just about any speed and any time ... Then just as it appears it will disappear... Then on again randomly
fyi .. Speed sensor ok and all other lights functioning
any ideas?
Old Jun 16, 2009 | 09:39 AM
Twisted Metal's Avatar
Twisted Metal
Check the abs sensor on the rear brakes. I had to make a panic stop on my 97, and it dislodged the sensor. The brakes continued to work fine, but the random abs light drove me nuts till i pulled the rear wheels and found it loose. Quick trip to the parts store to replace it, and no more light.
Old Jun 17, 2009 | 05:29 AM
speeddemon31176's Avatar
speeddemon31176
Check the plugs and wires where they enter the plug assemblies. I had the same problem and wasted 40 bucks on a sensor and it turned out that it was a poor connection. Try unplugging and plugging your connectors a few times and make sure they are fully seated then reset your computer and see if it goes out.
