Talk about a stubborn nut!
Old Jun 18, 2009 | 05:28 PM
  #31
Sheriff420's Avatar
Sheriff420
wd doesn't penetrate. if you're going to look for mine you need to find a place that sells CRC products.
  #32
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Linustratus
I found some of the ends at zumbrota bearing and gear, their website is www.zbag.com They want 98 and some change for the end and new nut. Still not cheap. ****ty deal all around, now im just wondering if i should just get both of em, just in case the other ones **** too.
I wouldn't worry about it until the time comes. But, on the other hand, it really can't hurt to have extra parts around. And you can always sell it if you get rid of the truck or something.
Old Jun 18, 2009 | 05:38 PM
  #33
zman17's Avatar
zman17
Originally Posted by VWandDodge
WD-40 sucks. It is nothing more than Kerosene. It evaporates rather quickly, and when people use it as a lubricant it actually collects dirt and gums up the works.
WD40 does suck! The Cyclo does everything it does, but it also penetrates. And as far as the evaporating goes, that is the exact problem I have with PB. If you try the Cyclo and compare it with the PB, you will see exactly what I mean.
Old Jun 18, 2009 | 05:57 PM
  #34
Sheriff420's Avatar
Sheriff420
http://www.deerelydeparted.com/p-317...ating-oil.aspx
thats the stuff my dad has sworn by for years. it says it penetrates to one millionth of an inch. i'd like to put the kroil oil, cyclo and knocker loose on equally frozen bolts and see which one is the best.
Old Jun 18, 2009 | 06:07 PM
  #35
zman17's Avatar
zman17
I'd like to do the same, but, it would be pretty hard to find equally frozen bolts. All I can go by is experience.
Old Jun 18, 2009 | 06:30 PM
  #36
Linustratus's Avatar
Linustratus
nah zman im keepin my baby till she completely pukes!! I kinda think the time is now to fix this stuff, while we have the weather up north here, and my new tires, i want to hit the mud n stuff and i cant with **** ujoints!
Old Jun 18, 2009 | 07:45 PM
  #37
Gary-L's Avatar
Gary-L
Veteran: Navy
Never heard of Cyclo. You probably made that up just to screw with people
I've heard Kroil is *the shiat*. Never used it, though.
Old Jun 18, 2009 | 09:09 PM
  #38
Synister1's Avatar
Synister1
Anyone who works on their vehicles (lift kits etc) should own a torque multiplier. Sometimes you just need 500ftlbs to break that suspension bolt loose.
Basic multipliers have a (3.3 or 3.4):1 ratio. Input 100 lb-ft, get 3xx lb-ft output. You can get a unit with a 2klb-ft max output for under $300 these days. Not cheap as that other tool posted, but it isn't 8 parts you have to assemble each time you go to use it. It's one of them tools you will not use that often, but when do need it you'll be glad you have it.
Old Jun 18, 2009 | 10:59 PM
  #39
Laramie1997's Avatar
Laramie1997
1+, I was trying to stay out of this thread....
I am glad I wasn't within 50 feet of you when you tried that stunt with the jack.
You put that much force on a socket wrench, not only are you trying to turn the nut, but you will be putting straight upwards force on the wrench..... Ever had on slip off when you were jerking on it? IT HURTS. I expected to see that wrench go zipping through the air in that vid.... Not that smart, I think. Respect my opinion before you flame me.
Old Jun 19, 2009 | 12:48 AM
  #40
95MaroonMonster's Avatar
95MaroonMonster
ive used Kroil, and thats some of the best stuff ive ever used, and you use it too, when your restoring a 60 some year old tractor
