front to rear height differences
Old Jun 20, 2009 | 02:25 AM
dakotas ram's Avatar
dakotas ram
Default front to rear height differences
my truck is a 2wd, i put 2" lowering shackles on the back of it and it is still 2" higher in the rear.....is that normal for the stock rear to pretty much be 4" higher than the front?.......i dont have any blocks or AAL on it......
Old Jun 20, 2009 | 02:37 AM
helms's Avatar
helms
its pretty normal for a full size to have a 4" rake. they are meant to take so much wieght without squatting. you could de-arch the springs 2" or put the stock shackles back in and get a flip kit, but bringing the rear down that far may require a c-notch to give the suspension some travel.
Old Jun 20, 2009 | 02:39 AM
dodge15004x45.9's Avatar
dodge15004x45.9
With about 1000lbs in the bed of my truck it stars to squat. Not to bad for a half ton.
Old Jun 21, 2009 | 11:24 PM
Trey318's Avatar
Trey318
Mine probably has like 2 1/4 rake if I took out the coil spring spacers. But I cant do that until I get my new rims/tires because my current tires rub.
