1998 Ram Needs Suspension Overhaul, What Parts Do I need?
Old Jun 20, 2009 | 07:55 AM
peterfromme's Avatar
peterfromme
Default 1998 Ram Needs Suspension Overhaul, What Parts Do I need?
Hello all. I just got a 1998 Ram 1500 4x4. The suspension of the truck is original, so with 140k miles, it's shot. I want to replace the suspension to improve the ride. What specific parts do I need to do this?
I was thinking of 4 new shocks and a new steering stabilizer, but what specific bushings do I need to get too?
Also, if I do the shocks myself, do I need to get a spring compressor?
Thanks,
pf
Old Jun 20, 2009 | 08:19 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You don't have to touch the springs. Remove the lower shock bolt and the three nuts holding the shock tower and remove it and the shock as one. Then remove the upper shock nut.
As far as everything else goes, get some one to turn the wheel left to right and check the tie rods and trac bar. Then raise it and grab the tire at 12 and 6 o'clock and look behind the wheel and see if the bj's and/or hub assemblies have any play.
Old Jun 20, 2009 | 12:03 PM
Sheriff420's Avatar
Sheriff420
i've heard good things about polyeurothane bushing kits, they stiffen up the ride and improve handling. the guy on a show called gearz on the speed channel said that if you were to do just one mod to your suspension that it should be the bushings. if you do get them you need to lube them because he said that if they're greaseless they'll squeak.
Old Jun 20, 2009 | 02:09 PM
Trey318's Avatar
Trey318
Energy Suspension makes the polyurethane bushings, which is what Ive got in my front end. Replace the shocks if they're leaky, tie rod ends, ball joints, and wheel bearings if there is any play in them. You should already have a steering stabilizer (sway bar), just replace the bushings with the ones in the Energy Suspension kit.
Oh and Energy Suspension makes rear end bushings as well for your leaf springs, but I didn't bother.
You might have difficulty taking the old bushings out if you dont have access to a press or aren't too confident. Local shops quoted me like $85 to remove the old ones and install the new ones, which is rather pricey. But taking the old ones out and putting new ones in can be kinda tricky.
