1995 Dodge Ram 1500 v-6, Getting no fire to coil
Hey Everyone, I need help.
95 Dodge Ram 1500, v-6 3.9 L. We have repaced the computer, coil, distributor, rotor, sensor in distributor, new battery. We are not getting spark to the coil, the fuel pump comes on, she will crank but no fire. Can anyone please help, my husband has had 3 major surgeries and can't help me, I need my truck running. Also could you tell me the palcement of the relays in the power distribution center, seems someone has taken my top. Any help would be appreciacted.
Thank you
Auntbk
Thank you
Auntbk
You're sure youre not getting any fire to the coil? Check your relays and make sure they're placed appropriately. Have you checked the crank and cam position sensors?
Heres a helpful link as well: https://dodgeforum.com/forum/2nd-gen...tmas-guys.html
The cam position sensor is located in the distributor. The crank position sensor is located near the outer edge of the flywheel (starter ring gear). Both are part of what controls fuel injection and spark events. Im gettin the locations out of the manual I linked you to, so if you need better diagrams or more information, look into that. Hope that helps.
