Wierd Problem Reversing
Old Jun 21, 2009 | 04:55 PM
mo1972's Avatar
mo1972
brakes should be good but i'll check it out. changed ball joints, pads ,rotors 2-3 months ago. I test drove for about 5 miles and when i got home same thing. Went in reverse and it went . back a few feet then stopped. Then I gave it more gas and it did go backwards but my rears were spinning a bit . I might pull front left wheel off first. I'll report back later
Old Jun 21, 2009 | 10:44 PM
mo1972's Avatar
mo1972
well I took off front tire and i am missing a bolt. I think it is the upper caliper adapter bolt. It is the thing that the shoes sit on and the caliper bolts to. Is that what is called ? I've been looking in my haynes manual. At least I know it is just a bolt . won't cost a bunch of $$$. That is very dangerous could have locked up at speed.
Old Jun 21, 2009 | 11:25 PM
dakotas ram's Avatar
dakotas ram
pic?........
Old Jun 22, 2009 | 01:12 AM
mo1972's Avatar
mo1972
can't post good pic but it's the thing you put new shoes on and bolt the caliper to. You have to take it off to change rotor . It bolts to the spindle with 2 large bolts . I am missing 1
Old Jun 22, 2009 | 01:19 AM
99DRAM31887's Avatar
99DRAM31887
you are talking about the brake caliper pen right you can go to autozone and buy 2 new bolts and my 97 uses a 3/8 hex key to remove them and while your at it you might as well buy a brake hardware kit and replace everything lol just dont forget the brake lube
Old Jun 22, 2009 | 01:25 AM
99DRAM31887
Old Jun 22, 2009 | 01:28 AM
dakotas ram
http://www.autozone.com/autozone/cat...chText=caliper
Old Jun 22, 2009 | 01:36 AM
99DRAM31887
yup yup those right there lol i tried to post a link but i failed epically lol
Old Jun 22, 2009 | 03:56 AM
mo1972's Avatar
mo1972
not those the caliper adapter bolt is what I need. the thing the brakes actually sit on. Not the caliper that squeezes them. The bolt is big. The other one has a head that is 13/16
Old Jun 22, 2009 | 04:01 AM
mo1972's Avatar
mo1972
http://dodgeram.info/tsb/2000/figures/05-06-00_f3.jpg
figure 3 in that picture
