Steering Column Clunk/ distributor cap burning up.
Old Jun 20, 2009 | 10:26 PM
estech2's Avatar
estech2
Default Steering Column Clunk/ distributor cap burning up.
I can feel it in the brake and gas peddle as well. Mostly when I take off from a stop. Already shimmed the column joint just passed the firewall in the E compartment and that took care of the shaking while driving but not the other. Also what could be causing the center lug on the distributor cap to burn up and become loose every 4 to 6 months. I have a stock coil.
Old Jun 20, 2009 | 11:53 PM
dakotas ram's Avatar
dakotas ram
that little bit of a clunk could be your shock mount bushings....mine are shot and make a clunk when taking off and stopping
for the dizzy, are you talking about the inside of it?....if so then make sure you arent putting it on at an angle and you are putting it on straight down, theyre easy to get on a little bit wrong and mess up
Old Jun 21, 2009 | 05:12 AM
estech2's Avatar
estech2
Thats mine too. Feels like the front axel is going to come out from under my truck. I don't feel it in the seat or the floor, just the steering column and the peddels. Weird!
Old Jun 22, 2009 | 05:32 AM
Sheriff420's Avatar
Sheriff420
one clunk cause is a worn out tranny mount but that'd be right under you and not in the front so maybe/maybe not. its worth a look, get under there and make sure its firm rubber and not coated in oil/atf. my camaro had a worn out one when i got it and if i got on it from a stop the transmission would hit the floor board.
