Front end help
Old Jun 22, 2009 | 04:26 PM
mugsaway's Avatar
mugsaway
Exclamation Front end help
I am stumped.....
Had a bad right front bearing - replaced but still feel sloppy front end.
Brought it to a few mechanics to have the front end checked out - all report ok. One even said the front end was "tight", even the suspect track bar.
I drive down the road and over regular cracks it feels sloppy - like something is loose. What else can be the problem? I thought maybe something in the steering, and perhaps it is, but I can feel it through the gas pedal also.
What problems have others experienced with the truck? What problems does my truck have that are persistent issues? I have a '99 Ram, 5.9, 4x4. Any help in pointing me in the right direction would be great.
Thanks all,
Mugs
Old Jun 22, 2009 | 07:07 PM
olyelr's Avatar
olyelr
When they checked the "front end" did they also check the steering shaft and gear box? These steering shafts are not as bad as the first gen's, but they still have there problems. And the gear boxes are pretty much junk at best.
Have someone saw the steering wheel back and forth a bit and see how much the pitman arm actually moves... there may be some slop in the steering gear itself, and possibly the shaft too.
Old Jun 23, 2009 | 12:55 AM
dakotas ram's Avatar
dakotas ram
balljoints?.......you might just get you a steering stabilizer
Old Jun 23, 2009 | 01:02 AM
xray99's Avatar
xray99
I would imagine any front end guy worth a damn would not miss defective ball joints, tie rods ect.
Have you checked control arm bushings ?
Depleted bushings can cause a mushy feel.
Spent shocks can also make the front end feel sloppy.
