fan clutch removal
Old Apr 27, 2010 | 10:03 PM
dodgeram07's Avatar
dodgeram07
this is what i did
Old Sep 19, 2011 | 07:28 PM
redneck_ram's Avatar
redneck_ram
trying to get my clutch fan off as well. goingto try what sherriff did in the am. hopefully itll work, if not gonna drill the holes in some metal and use that instead.
Old Sep 19, 2011 | 09:32 PM
Hahns5.2's Avatar
Hahns5.2
Put a wrench on the nut and hit it with a hammer, it usually takes a few tries but always works for me.
Old Sep 19, 2011 | 09:40 PM
Sheriff420's Avatar
Sheriff420
My idea worked on my dads truck but not on mine. I grabbed a piece of flat steel and a couple pieces of dowel then made a wrench for it. The steel/bolt deal is a good one if you don't have a welder.
Old Sep 20, 2011 | 12:00 AM
gdstock's Avatar
gdstock
Originally Posted by dodgeram07
this is what i did
I plan to replace water pump when I install the kegger. What is the distance between centers on this" Anyone know the distance across the two holes opposite each other? I have a few spanners, but don't know if they will fit or if I have to fab something like this.
Thanks.
Old Sep 20, 2011 | 12:37 AM
merc225hp's Avatar
merc225hp
You can use a flat piece of 1” x 1/8" flat stock with just one hole in the end for the bolt, The bar will rest on the fan nut for the other rest point, you will have room in there for a wrench as well. A nylon strap wrench or a rubber one will work on the pulley as well.
