cleaning injectors and lines
Old Jun 23, 2009 | 04:01 PM
jarebear86's Avatar
jarebear86
Default cleaning injectors and lines
what is the best way to clean the fuel lines and the fuel injectors and is it hard?
Old Jun 23, 2009 | 04:12 PM
zman17's Avatar
zman17
Retired Moderator - RIP
By replacing them with new ones! Seriously though, it's not hard. Just pull the fuel rails and soak them in some carb cleaner. As far as the injectors go, there are some people on here that have purchased a ***elery cleaner machine from Walmart and put carb cleaner in it (I think). Maybe one of them will chime in and give some more info.
Old Jun 23, 2009 | 06:43 PM
jarebear86's Avatar
jarebear86
how long should i soak them and would i need to soak the fuel line from the gas tank to the fuel rails too or no? and in the (as u say) ***elery cleaner machine do i use carb cleaner there too or what?
Old Jun 23, 2009 | 06:48 PM
Trey318's Avatar
Trey318
My dad has an old Snap-on fuel injector cleaner. It hooks up to the fuel line and uses compressed air to force some special injector cleaner concentrate/gasoline mix in at the appropriate PSI and you actually run the vehicle off of it until you use all the fluid.
