Stealership? Transmission Flush
Old Jun 23, 2009 | 05:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Because they are charging you for what they ran through it, and I hope they used atf+4.
Old Jun 23, 2009 | 06:40 PM
Linustratus's Avatar
Linustratus
I think you guys are all nuts. You have to ask for what you want if they dont just come right out and tell you what they are going to do, and you will (or at least should) get just that. In my shop, i do trans flushes all the time, and with the right cleaner prior to flush, and conditioner afterwords, your trans should be perfect unless something else is going on. Ive actually tested it on my ram, did a flush with and without the cleaner, and the filter looked exactly the same. I didnt buy the whole cleaner/flush thing, so i had to do it. Wouldnt sell something i wasnt sure about. I guess it also depends on what the old fluid looked like too. So i dunno, you know what they say about opinions...... Also, for any trans flush/filter change, it should be no more than 200.00 at most. Bummer for you, I would go raise hell i guess.
Old Jun 23, 2009 | 06:50 PM
Linustratus
Originally Posted by dadgemanjoe
Check this out..just got a 2001 Dodge Ram 1500 and loving it. Took her to the dealer for a transmission "flush" My assumption was they remove all the fluid ...including the fluid in the tourque converter. They charged me 250 bucks.
I crawled underneath last night and noticed the tranny pan has not even been dropped. So that means the filter was not changed.
Has anyone else ever heard of anything like this? I think they pulled all the fluid out and refilled it and never changed the filter.
Your other problem is you took it to a dealership......
Old Jun 23, 2009 | 07:07 PM
lastrights's Avatar
lastrights
ah man your going to need a tranny rebuild in no time
Old Jun 23, 2009 | 07:40 PM
sawtooth's Avatar
sawtooth
TSB
http://dodgeram.info/tsb/2007/26-003-07.htm
If you are going to drop the pan for a filter change, you might consider installing a transmission drain plug. http://www.summitracing.com/search/?...ug%20kit&dds=1
Old Jun 23, 2009 | 07:54 PM
DODGEIT105's Avatar
DODGEIT105
On a flush they completely replace all the fluid so it will take more to refill it. Dropping the pan and changing the fluid does not take as much since some of the old fluid remains in the system. i.e.Torque converter, lines and what is trapped up above the valve body. However changing the filter and adding fresh fluid will renew the remaining old fluid and not really cause any harm. It is the recommended way to do it. You will need ATF+4 or equivilent fluid since yours is a 2001. ATF+3 will cause torque converter shudder on 2001 and newer units.
Old Jun 23, 2009 | 08:10 PM
Miami_Son's Avatar
Miami_Son
Actually, more old fluid remains in the system than is drained out when done this way. So long as the fluid hasn't been subjected to overheating or abuse, this is the recommended procedure. If the old fluid smells burned, is discolored or there are metal shavings present, the entire system should be flushed and refilled.
Old Jun 23, 2009 | 09:02 PM
dodge15004x45.9's Avatar
dodge15004x45.9
My shop it was 50 bucks! Tom I plan to drop the pan and change filter and gasket.
Old Jun 23, 2009 | 09:11 PM
charlie1935's Avatar
charlie1935
Had mine flushed at 77000 miles. Also had them drop the pan, adjust bands and new filter. It cost me more that way but that's what I wanted. At that time (about 4 1/2 years ago) that cost me $244.00.
Old Jun 23, 2009 | 09:15 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Originally Posted by sawtooth
TSB
That TSB like most DODGE TSBs can be read two different ways. It means no FLUSHING, be careful and don't take it to mean no fluid changes (Not you sawtooth, but anyone else reading it). I agree that the drain plug is a great idea. Without one you will always make a huge mess. That is what I dread about doing a tranny filter change. I have thought about installing a drain plug but always worried it might hit a moving part or something.
I did a tranny fluid change recently and I couldn't find ATF+3 anywhere, (my 97 has ATF+3 in her) it's not made any more. I upgraded mine to ATF+4 since it is backward compatible. It actually shifted a little smoother after the change.
Of coarse there will always be metal shavings (or metalized goop) on the magnet (again just clarifying, so no one panics).
