Maplight problem for noob
Old Jun 23, 2009 | 11:06 PM
BD APL's Avatar
BD APL
Default Maplight problem for noob
Hello. I'm a noob here and am hoping I can find as much good info here as on my usual motorcycle forum. I've been the proud owner of a 99 1500 since she was new. I've just recently developed a problem with the passenger maplight. It no longer will "push in, then pop out". It rattles loose in or out. Seems like a spring is broken or something. However the real problem is that now the damn light is intermittently coming on. Even if my ignition isn't on. That worries me b/c who wants a dead battery?! Here's the big question: I can't figure out how to get to the bulb. The dome light was easy, but I can't seem to figure out how to pop it out. I suspect this is an easy fix, I'm just not seeing it. Thanks in advance for the help.
BD APL
Old Jun 23, 2009 | 11:22 PM
Laramie1997's Avatar
Laramie1997
There are two screws towards the front of the OVH that you need to remove, then you can slide it back and drop the whole assembly. More than likely, you knocked the little plastic frame out of whack, and that's what stopped it from clicking on and off. Should also be your on and off problem too.
