95 ram, cranks, no spark, no fuel
Old Jun 23, 2009 | 11:07 PM
jusber15's Avatar
jusber15
Default 95 ram, cranks, no spark, no fuel
I have a 1995 Ram 1500 4X4, 5.9L. I parked it in my driveway and the next day it wouldnt start. I started checking some things out to try and diagnose whats going on. The check engine light comes on when I turn the key to the run position. All fuses have been checked and are good. The fuel pressure is within specs, I checked it with a gauge. I'm not getting any spark. I checked to see if the injectors were firing using an injector light. When I turn the key to the run position, all the injectors will pulse once, but they will not pulse while cranking. Sounded like the crankshaft position sensor went bad. I replaced the sensor tonight and still the same situation. There went 75.00 into the trash. Now I don't know where to turn. Thats where you guys come in to help. I searched around trying to find someone that has my same problem, but I never found a solution. Any ideas on whats up?
Old Jun 25, 2009 | 01:38 AM
jusber15's Avatar
jusber15
Changed the ASD relay today, still nothing. Any ideas??
